Hi I'm trying to make a simple circuit witch will send ASCII symbol to PC over RS232.
I looked through some tutorials (like this one: http://arduino.cc/en/Tutorial/ArduinoSoftwareRS232) and always there are some other pins used for Rx and Tx.
So I was wondering: What are Rx and Tx pins (in Digital Pins section) for ? Can I just hook those to to RS232 ?
Pins 0 (receive) and 1 (xmit) are assigned to the built in hardware UART of the AVR processor chip. They can not be wired directly to RS-232 as they are TTL (0-5vdc) levels and RS-232 is bipolar and higher voltages. A voltage conversion chip like the MAX232 is required to directly wire to RS-232 voltage.
There are also Arduino software library routines that allow serial communications on any digital pins via software functions that emulate what the hardware UART does. They would still require voltage conversion for direct RS-232 hookup.
Is it safe to say that digital pins 0 and 1 should NOT be used for anything else besides serial communication?
No. You can use them as standard digital IO pins, you just can't use them for serial communications at the same time. I don't think there's a good way to switch back and forth, either.
Are there any other “reserved” pins in the standard headers?
Not really. Pins 0 & 1 can still be used for applications other then serial communications. One just has to keep in mind that external components wired to pins 0 & 1 may prevent successful uploading from the Arduino IDE, unless there is means to disconnect them. If one is using say a shield for all external components then it would be pretty simple to remove the shield if future uploads needed to be performed.
Pin 13 has a LED and series resistor to ground, so if it was to be used as an input pin then the driving circuit would have to be able to provide the drive current that the LED/resistor would draw.
Many of the AVR I/O pins serve dual functions as well as being general purpose I/O pins. Pins 2 & 3 are available as user interrupt input pins if desired, and all the analog input pins can be utilized as digital pins if desired. Different I/O pins are supported by internal timers, some 8 bit, some 16 bits.
Lots of this info is in the Arduino reference and playground sections on their site. Also the AVR data sheet is the ultimate bible for all hardware features of the chip.
