Rx TX pins on uno with Arduino motor shield.
I want some info on all the RX and TX pins that we can use on a Arduino Uno for my blue tooth JY-MCU module. I need to utilize the software serial to enable a different RX/TX pin other use the hardware based 0 and 1 RX/TX pins. Also I using the motor shield along with it.
I was successfully able to connect the bluetooth module using pin 10 and 9 , but I want use any another pin, since pin 9 is used for motor brake control from the Arduino motor shield. Are there any other pins, that I can use for RX/TX other than the motor control pins
Function pins per Ch. A pins per Ch. B
Direction D12 D13
PWW D3 D11
Brake D9 D8
Current Sensing A0 A1
Softwareserial can use any 2 i/o-pins, and you can have multiple channels
see in reference
What model of Arduino are you using? A Leonardo has some restrictions on what pins you can use for the RX pin.
