RX8010 timer interrupt
tried a forum search
didn't find anything
has anyone used an Epson RX8010 RTC to generate a fixed interval interrupt?
it looks like it should be doable, but I'm struggling ...
The RX8010SJ runs on 5V so you should be able to connect the IRQ1 and IRQ2 pins to Pin 2 and Pin 3, the two external interrupts of the Arduino UNO. Since IRQ1 is an Open Drain output, be sure to provide a pull-up resistor. Use attachInterrupt() to associate a function with an interrupt.
Keep your interrupt functions short!
hello John
thanks
in fact Arduino and RTC both running off a single 3.7 volt LiPo
interrupt IRQ1 is attached to D4
pinMode INPUT_PULLUP
interrupt vector just sets a boolean "we got woken up"
it's enough that it wakes a slumbering 'duino
I was struggling to get the RX8010 to generate IRQ1 every 55 seconds
spent ages writing a really neat routine
then noticed I forgot to call it!!!!! d'oh!
here's my code for amusement ...
// tick indicator
volatile boolean tick;
ISR(PCINT2_vect)
  // handle pin change interrupt for D0 to D7 here
  tick = true;
  // end of PCINT2_vect
void setupWakeTick(void)
  // pin change interrupt
  PCMSK2 |= bit (PCINT20); // want pin D4
  PCIFR  |= bit (PCIF2);   // clear any outstanding interrupts
  PCICR  |= bit (PCIE2);   // enable pin change interrupts for D0 to D7
  tick = false;
void RX8010initClock(void)
  // initialise clock chip
  RX8010writeReg(RES_17, 0xD8);
  RX8010writeReg(MIN_ALARM, 0x00);
  RX8010writeReg(HOUR_ALARM, 0x00);
  RX8010writeReg(CON_REG, 0x00);
  RX8010writeReg(WADA_ALARM, 0x00);
  RX8010writeReg(RES_30, 0x00);
  RX8010writeReg(RES_31, 0x08);
  // !TE and TSEL2, TSEL1, TSEL0
  //             0      1      0
  //                         1Hz
  RX8010writeReg(EXT_REG, TSEL1);
  // tick counter
  RX8010writeReg(TIMER1, 0);
  RX8010writeReg(TIMER0, 55);
  // no alarms
  // but we do want timer interrupts
  RX8010writeReg(CON_REG, TIE);
  // interrupt on IRQ1
  RX8010writeReg(IRQ_CON, TMPIN);
  // now enable the timer
  RX8010writeReg(EXT_REG, TSEL1 + TE);
  // set and clear TSTP
  RX8010writeReg(CON_REG, TIE + TSTP);
  // clear flags
  RX8010writeReg(FLAG_REG, 0x00);
Hello gentlemen,
Can you share which library are you using?
Thank you,
Dave
