Moet er toch maar een vraag van maken, beginstand van de kwh.
Hoe kan ik in de sketch
* FILE: KWh monitoring
* AUTHOR: Rob Tillaart
* DATE: 2010 03 31
* URL: http://playground.arduino.cc/Main/EEM12L-32AKWhMonitoring
* PURPOSE: prototype KWh monitoring
* Digital Pin layout ARDUINO
* 2 IRQ 0 - to KW meter EEM12L-32A
* This KWh meter gives a pulse every 0.5 Watt
// KWH SENSOR CODE
// TODO - make a class
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xAF, 0x82, 0x31, 0x30};
IPAddress ip(192, 168, 2, 7);
IPAddress dnServer(8, 8, 8, 8);
IPAddress gateway(192,168,2,254);
IPAddress subnet(255, 255, 255, 0);
IPAddress server(0,0,0,0);
char serverName[] = "www.mijnwebsite.com";
EthernetClient client;
char input; // incoming serial data (byte)
bool readnextLine = false;
#define BUFSIZE 500
char buffer[BUFSIZE]; //Buffer for serial data to find \n .
unsigned long kwh = 0; // pulse
unsigned long sum = 0; // sum pulse
unsigned long lastTime = 0; // will store last time
unsigned long interval = 60000; // interval at which to blink (milliseconds)60000
volatile unsigned long rpk = 0; // raw pulse KWH counter (private)
volatile unsigned long rpk_old = 0; // value of last read (private)
volatile boolean CS_kwh = false; // Critical Section for KWH meter (private)
// The interrupt routine
void Kirq()
rpk++; // just increment raw pulse counter.
if (rpk > 1000000000) // reset pulse counter after 10e9 pulse = 500.000 KW
if (false == CS_kwh) // in critical section? // assumption IRQ-call is handled atomic on arduino.
rpk -= rpk_old;
rpk_old = 0;
// returns kwh's since last reset
float readkwh1()
return rpk / 1000.0; // one pulse = 0.5 watt.
// returns kwh's since last call
float readkwh()
CS_kwh = true; // Start Critical Section - prevent interrupt Kirq() from changing rpk & rpk_old ;
long t = rpk; // store the raw pulse counter in a temp var.
long k = t - rpk_old; // subtract last measure to get delta
rpk_old = t; // remember old value
CS_kwh = false; // End Critical Section
return k/2000.0; // return delta, one pulse = 0.5 watt.
// SETUP
Serial.print("Start ");
Serial.println(__FILE__);
//Ethernet.begin(mac, ip);
Ethernet.begin(mac);
pinMode(4, OUTPUT); // SD select pin
digitalWrite(4, HIGH); // Explicitly disable SD
// KWH interrupt attached to IRQ 0 = pin2
attachInterrupt(0, Kirq, FALLING);
// MAIN LOOP
if (millis() - lastTime > interval) {
lastTime = millis();
// read the pulses
kwh = readkwh1();
sum += kwh;
// send new data
httpRequest();
float kwh = readkwh();
float sum = readkwh1();
Serial.print("kwh: ");
Serial.print(kwh, 5);
Serial.print(" ");
Serial.println(sum, 5);
void httpRequest()
// if there's a successful connection:
if (client.connect(serverName, 80))
{ float kwh = readkwh();
Serial.print("GET /datalogger/p32.php?kwh=");
Serial.print(kwh, 4);
Serial.print("&sum=");
Serial.print(sum, 4);
Serial.println(" HTTP/1.1");
Serial.println("Host: mijnwebsite.com");
Serial.println("User-Agent: arduino-ethernet");
Serial.println("Connection: stop/close");
Serial.println("web ");
client.print("GET /datalogger/p32.php?kwh=");
client.print(kwh, 4);
client.print("&sum=");
client.print(sum, 4);;
client.println(" HTTP/1.1");
client.println("Host: mijnwebsite.com");
client.println("User-Agent: arduino-ethernet");
client.println("Connection: close");
//Request complete; empty recieve buffer
while (client.available())
char c = client.read(); //gets byte from ethernet buffer
if (client.available() == false)
delay(25); // give some extra time for next packet to arrive
client.println();
Serial.println("Success!");
Serial.println("Failed");
client.stop();
// END OF PROGRAM
of in de bijbehorende bestanden de beginstand aanpassen.
Want wanneer de arduino opnieuw opstart is de tellerstand weg en begint die weer opnieuw op 0.
Heb geprobeerd om in de weergave ,en of in de database de rekenen om zodoende de juiste tellerstand te verkrijgen, mij niet gelukt.
Want mij kwh meter staat niet op nul maar heeft tellerstand 00061,5.
