ok thanks here you go
#include <S1D13700.h>
#include "lucida_font.h"
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
int rpm = 0;
int airTemp = 0;
int Battery = 0;
int WaterTemp = 0;
int Gear = 0;
int fuelP = 0;
int Kph = 0;
int oilP = 0;
int fuelLevel = 0;
int val = 0;
int last_val;
MCP_CAN CAN(53);
S1D13700 glcd;
char newData[12];
char newRPM[12];
char newTemp[12];
char newBattery[12];
char newfuelP[12];
char newKph[12];
char newoilP[12];
char newval[12];
//Serial.begin(115200);
CAN.begin(CAN_1000KBPS); // init can bus : baudrate = 1000k
pinMode(2, INPUT); // Setting pin 2 for /INT input
glcd.initLCD();
glcd.clearText();
glcd.clearGraphic();
glcd.textGoTo(10,1);
glcd.writeBitmapText("JDM Dyno ",100,100, LUCIDA_FONT);
delay(2000);
/*Clear the screen */
glcd.clearText();
glcd.writeBitmapText("Water Temp: ",10, 5, LUCIDA_FONT);
glcd.writeBitmapText("Fuel P:",10, 40, LUCIDA_FONT);
glcd.writeBitmapText("Oil P:",10, 80, LUCIDA_FONT);
glcd.writeBitmapText("Battery:",10, 120, LUCIDA_FONT);
glcd.writeBitmapText("MPH:",10, 160, LUCIDA_FONT);
glcd.writeBitmapText("Fuel Level:",10, 200, LUCIDA_FONT);
if(!digitalRead(2)) // If pin 2 is low, read receive buffer
CAN.readMsgBuf(&len, rxBuf); // Read data: len = data length, buf = data byte(s)
rxId = CAN.getCanId(); // Get message ID
val = analogRead(A0); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, -1, 101);
delay(100);
if(last_val!=val)
last_val = val;
// Serial.println(val);
/*Serial.print("oilP: ");
Serial.println(oilP);
Serial.print("WaterTemp: ");
Serial.println(WaterTemp);
Serial.print("Battery: ");
Serial.println(Battery);
Serial.print("Gear: ");
Serial.println(Gear);
Serial.print("fuel: ");
Serial.println(newval);
itoa (WaterTemp, newTemp, 10);
glcd.writeBitmapText(newTemp,190, 5, LUCIDA_FONT);
itoa (fuelP, newfuelP, 10);
glcd.writeBitmapText(newfuelP,125, 40, LUCIDA_FONT);
glcd.writeBitmapText(" ",140, 80, LUCIDA_FONT);
itoa (oilP, newoilP, 10);
glcd.writeBitmapText(newoilP,110, 80, LUCIDA_FONT);
itoa (Battery, newBattery, 10);
glcd.writeBitmapText(newBattery,150, 120, LUCIDA_FONT);
itoa (Kph, newKph, 10);
glcd.writeBitmapText(" ",120, 160, LUCIDA_FONT);
glcd.writeBitmapText(newKph,80, 160, LUCIDA_FONT);
itoa (val, newval, 10);
glcd.writeBitmapText(" % ",220, 200, LUCIDA_FONT);
glcd.writeBitmapText(newval,190, 200, LUCIDA_FONT);
switch (rxId){
case 0x2000:
rpm = rxBuf[1] * 256 + rxBuf[0];
airTemp = rxBuf[6];
WaterTemp = rxBuf[4];
case 0x2002:
fuelP = rxBuf[0];
Battery = rxBuf[4] ;
case 0x2003:
Gear = rxBuf[0];
case 0x2001:
Kph = rxBuf[4] / 1.6;
oilP = rxBuf[6];
Hope someone can help
let me know if you need the #included files
thanks
