I was wondering if someone could help me design a program that can run 2 different dc motor with a sabertooth controller (i have one, and have been using it for segways and stuff) The problem is i don't know how to write a standard like motor1 run until delay and motor 2 run until delay, type with the sabertooth. Also for the motors speed to be controlled with a potentiometer. So basically the motors have button inputs for left and right steering, and then for forward (straight ) control where both motors are running in the same direction, and a potentiometer would control the speed for that.
example if (button 1 = on) {
motor1 - forward
delay (1000);
example if (button 2 = on) {
motor2 -forward
for steering and
potentiometer would control the speed.
so if val = i < 0 {
val = motor1 - forward
val = motor2 -forward
} until u moved the potentiometer to 0 again.
this obviously isn't real code but i just wrote this to explain the type of function im talking about.
and also it would be cool if we could use the potentiometer for steering as well.
Thanks to anyone that wants to help!
