Safe with LCD ;2 MICRO SERVOS; MICROSWITCH;2LEDS;FINGERPRINT
Okay Guys i need help with a code for my project i have and lcd,and servo that works,now the 2leds,microswitch and fingerprint i cant get to work.
i need help i do not understand very much of programming im trying to learn a bit by bit,and sorry for my english.
here is my code this code works with lcd and 2micro servos now i need is microswitch to work with the 2 leds when it detects the door and fingerprint this is all i need. Ty
#include <Servo.h>;
const int servoPin1 = 13;
const int servoPin2 = 12;
Servo servo1;
Servo servo2;
int counter = 0;
#include <Keypad.h>
const byte numRows = 4; //number of rows on the keypad
const byte numCols = 4; //number of columns on the keypad
int PIN_CODE[4] = {2, 5, 8, 0};
int PIN_INTRO[4];
int flag = 0;
int ERRO = 0;
/*keymap defines the key pressed according to the row and columns just as appears on the keypad*/
char keymap[numRows][numCols] =
 {'1', '2', '3', 'A'},
 {'4', '5', '6', 'B'},
 {'7', '8', '9', 'C'},
 {'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {11, 10, 9, 8}; //Rows 0 to 3
byte colPins[numCols] = {7, 6, 5, 4}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad = Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
#include <Wire.h>
// Inicializa o display no endereco 0x27
LiquidCrystal_I2C lcd(0x3f, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
 PIN_CODE[0] = '2';
 PIN_CODE[1] = '5';
 PIN_CODE[2] = '8';
 PIN_CODE[3] = '0';
 lcd.begin (16, 2);
 lcd.setBacklight(HIGH);
 lcd.setCursor(0, 0);
 lcd.print("Arduino 12TGEI");
 lcd.setCursor(0, 1);
 lcd.print("LCD e modulo I2C");
 pinMode( 2 , INPUT );
servo1.attach (servoPin1);
servo2.attach (servoPin2);
servo1.write (80);
servo2.write (150);
//If key is pressed, this key is stored in keypressed variable
//If key is not equal to NO_KEY, then this key is printed out
//if count=17, then count is reset back to 0 (this means no key is pressed during the whole keypad scan process
 int keypressed = myKeypad.getKey();
 if (keypressed != NO_KEY)
   Serial.println(keypressed);
   Serial.println(flag);
   if (flag < 4) {
     if (flag == 0) {
       lcd.print(" INTRODUZIR PIN ");
       lcd.print("                 ");
       lcd.setCursor(1, 1);
     lcd.print("  *");
     PIN_INTRO[flag] = keypressed;
     Serial.print("flag = ");
     Serial.print("PIN_INTRO["); Serial.print(flag); Serial.print("]="); Serial.println(PIN_INTRO[flag]);
     Serial.print("PIN_CODE["); Serial.print(flag); Serial.print("]="); Serial.println(PIN_CODE[flag]);
     flag++;
   if (flag == 4) {
     valida();
     flag = 0;
void valida()
 ERRO = 0;
 for (int i = 0; i < 4; i++) {
   if (PIN_INTRO != PIN_CODE) {
     Serial.print("PIN_INTRO["); Serial.print(i); Serial.print("]="); Serial.println(PIN_INTRO);
     Serial.print("PIN_CODE["); Serial.print(i); Serial.print("]="); Serial.println(PIN_CODE);
     ERRO++;
 Serial.print("ERRO = ");
 Serial.println(ERRO);
 if (ERRO == 0) {
   lcd.print("   PIN CORRETO ");
   lcd.print("   ABRIR PORTA  ");
   servo1.write (80);
   servo2.write (150);
   delay(2000);
   lcd.print("                ");
   lcd.print("   PIN ERRADO  ");
   lcd.print("                ");
   servo1.write (150);
   servo2.write (75);
   delay(2000);
   lcd.print("                ");
 flag = 0;
How IS the switch wired to this pin? INPUT_PULLUP would make for much simpler wiring - connect one leg to the pin, connect the other leg to ground.
Where do you read the state of this pin?
What presses/releases the switch connected to this pin?
What fingerprint scanner do you have? How is it connected? Where is the code to read a fingerprint?
PaulS:
This code neither microswitch neither leds or fingerprint is connected to the code ;what i need help for is to put in the code all connected.
I have this sensor fingerprint
the microswith is pressed with a a screw when the door is closed.
