Safely assembling my project
Review for Dyson Cinetic Big Ball Animal Canister Vacuum
Do you agree or disagree that our modern life nowadays has left us so busy that we are barely able to take care of ourselves, let alone taking care properly of our own homes? Whether you agree or not, at least we all can be certain that our life nowadays involves a very busy lifestyle. Hence that is why we need extra helpers to make sure we get our jobs done quickly in a timely manner!
For our cleaning chores, it is very fortunate that nowadays we have the vacuum cleaner. A vacuum cleaner is a machine that can help you make short work of most cleaning sessions without having to spend a whole day cleaning. And among all the vacuum cleaner options available, some brands do stand out with their products as they always receive very favorable vacuum cleaner ratings Best Rated Vacuum Cleaners: The Best for Cleaning.
For example, the Dyson brand. Being in the industry for more than a hundred years, Dyson truly has the experience to back up their fame. And their vacuum cleaners are always renowned for their efficiency and effectiveness. Below, we are going to introduce to you an option from the catalog of Dyson that we believe to possess all the good qualities of a good vacuum cleaner, and that is the Dyson Cinetic Big Ball Animal Canister Vacuum.
0801 - 51
Overview
Coming from the well-known brand of Dyson, of course there will be a lot to be expected from this vacuum cleaner. The first is the suction power, which is further enhanced by Dyson’s signature Cyclone technology. What this means is that the Cyclone technology allows Dyson vacuum cleaners to produce great suction power on par with the best vacuum in the world, while utilizing the least amount of energy to generate it. That is going to save you a lot in electricity bills!
See Also: The Unexpected Choice: Top Rated Vacuum Cleaners Revealed !
Having talked about the suction power, this vacuum cleaner surely makes the Dyson family proud by continuing the Dyson’s reputation for excellence in suction power. And while the vacuum cleaner can produce great suction power, it is also equipped with the ability to maintain and keep that suction power constant over a long time period, or at least until the dirt cup is filled.
0801 - 52
Please be advised that the vacuum cleaner does not come with a filter in its design, but it makes up for its lack of filtration by trapping dirt and debris in its cyclone. This allows the vacuum cleaner to require very little of your maintenance, apart from emptying the dirt cup when it is filled up. Other than that, the vacuum cleaner has a high degree of maneuverability, being able to reach far and wide into difficult corners and even further with the extra accessories that come with the machine.
Conclusion
You can never go wrong with a Dyson vacuum cleaner, and you know that you are in good care with this Dyson Cinetic Big Ball Animal Canister Vacuum. This is a very decent choice if you don’t mind having to clean the dirt cup occasionally. It is no wonder that Dyson vacuum cleaners always have their own spot in The Best Vacuum Cleaner, whether it be the top spots or not.
Are we dealing with AC or DC? Are you building the converter? Are you using 220v mains line voltage and does you mains circuit include a ground connection?
Paul
Yes. Keep high voltage away from low voltage. One of the worst ways to screw up is if a loose wire on the low voltage side gets across to the high voltage side.
You aren't as careful with the 5V wiring so that is likely to be where the fault starts from. If the HV side is a long way away and maybe there is a barrier like the converter module itself filling up most of the space then it is safer.
I hate having to say this because I hate having to quash people's enthusiasm; Please don't do this project. It is quite obvious from your question and comments that you do not know enough about electricity to work with mains safely without supervision.
While people can provide answers to your questions we cannot give you the necessary electrical safely training nor can we supervise you and keep you safe.
Please work on a low voltage project, build up your knowledge up to the point where you know why I am saying this.
Don't lose interest because I've said this and don't lose your life by ignoring my advice.
First pay your life insurance and make me a beneficiary! Your description is ambiguous and needs more details. Is the 220V to 24V converter actually a power supply enclosed in a metal frame? Is it a wall rat? How many amps are you talking about? If it is in an enclosed frame you probably will be OK but do earth the frame. Do you have a bud that is an electrician, if so talk to him about the mains and what your code requires. Consider purchasing a LAB power supply, about $60 on eBay, this will allow you to use the 220V safely and protect your circuit from shorts etc. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
Not bringing mains voltage into your project is the best advice. The only time you want mains inside a project is if you’re doing something directly with that voltage, like a light dimmer but those kinds of projects are simply not safe for those that do not understand the inherent dangers. Mains voltage will kill you. Period.
Use an external power supply, there is reason why wall warts and power supply bricks are available in every practical voltage with wattage. Seriously, buy a quality supply from DigiKey or Element14 or other reputable distributor in your country, don’t take chances with the Wung-hung-low crap from China. There are plenty of videos on YouTube, especially EEVBlog that will show you how bad and dangerous some of those devices can be.
If you must work with mains, you must properly ground (earth) all metal and ensure you switch the line, not the neutral. Maintain proper color coding (example: blue/brown/yellow-green) and always fuse the the device. Always heat shrink all connection points or use insulated crimp connections. Keep HV away from LV as far as possible, sometimes double insulation is required (tubing or heat shrink over twisted together switch wires as an example).
One last thought: Never use Chinese equipment as an example, something is wrong with that stuff about 99% of the time.
tartarus:
I am new to electronics, and am looking toward assembling my first project. I will be using a 220v to 24v converter, so part of my project will be high voltage.
Why not using an external, ready made 24V adapter?
Indeed, don't bring mains on your PCB unless you have another use for it. It's so much easier to design a board that only uses low voltage, and connects to an external power brick.
In short, you've been told! :cold_sweat:
