Hello,
The following is further work relating to my original experiments in this thread.
For an experiment I am conducting I have purchased a DM2282 Drive and a NEMA 42 motor.
What I want to do is to power and run the motor at a CONSTANT speed, preferably as slow as possible (very low RPM).
I have several resources I've checked for the connections and wiring such as:
Driver Manual
and images like the one attached to the post.
Since I am not an engineer and my knowledge of circuits and electronics is almost zero, I am worried that my chances of burning either the motor or the driver are quite high on first trial...
In order to avoid this, I would love to understand what I can and cannot do:
Can I power the DM2282 with a wall power supply directly? a regular 220-240V that is?
This tutorial powers it with a separate 24V power supply.. I'm wondering if I need to buy that as well or not. -
Like the picture attached (which I found online), can I attach the system in the following sequence:
Power Supply --> DM2282--> NEMA 42--> Arduino --> USB 5v
or do I need some power control / resistors or a way to prevent things from exploding/burning up? I realize the driver should have most of these mechanisms built-in...
- I could not really understand from the driver pdf, which are the recommended power settings for this specific driver.
Any help on these issues would be appreciated
Thank you and again apologies for the limited knowledge I come with to this issue.
