My names Bob and I am doing a upgrade on a 1956 king fisher sailboat . I am trying to make this boat awesome as far as technology upgrades. I have made many upgrades to the electrical system to make this boat a efficient single handed sailing boat.
To the point I want to use Arduino to control all the Led lighting on my boat from my smart phone via bluetooth. I am also installing a 10 horsepower manta 2 electric drive running on 36 volts. I need forward and reverse and variable speed control. This motor has a high amp load it would be awesome to control this with a slider switch app. There are controllers on the market but in my opinion they are ridiculously priced.
I want to know which board you would recommend for this application with room for expansion. I know I will need a relay array , I plan on getting the 16 relay board for the lighting . However the amp rating on these relays are not high enough for the propulsion motor so suggestions are needed . The lighting will be my first step and the motor control as I become more familiar with the the capabilities of the hardware and codes used.
I know I have to learn all this . I will do my homework , I just want to get the hardware correct to begin with so I can purchase them and get the pdf files .
Any help getting me up and running here is greatly appreciated.
Controllers for 10 horsepower electric motors need to be professionally designed and manufactured (and I would look for a solid guarantee) so that will be the hard part. There aren't any on the hobby market.
For controlling LEDs, I would use MOSFETs instead of relays. MOSFETs will consume much less current than relays and are probably more reliable in that enviromnent.
jremington:
groundfungus:
Those high current relays will be an expensive failure. The contacts will probably fuse due to the startup current of the motor.
The >200 amps estimated above are for the normal load operating conditions of the motor. However, brushed DC motors briefly draw the stall current upon startup, which can be ten times higher than the normal load current. You need a controller than can either handle the startup current or employs "soft start" technology to limit the initial motor current.
Hi, how are you planning to power these motors, what power source.
Submarine batteries come to mind, but in a sailboat they might just do that, turn it into a submarine.
jremington:
Can 3 , 12 volt deep cycle marine batteries deliver up to 10 times the 200 amps? The relay is rated at 450 amp. Perhaps it may fail however these have been used on numerous projects with the manta two motor . Its 10 hp peak and 6 hp nominal. The spec sheet for the motor is on the same page. 10 hp Permanent Magnet Motor
