SainSmart 1.8 LCD Help
Hey guys so this works great! Although I am having some troubles with finding out how to display data.
If I try: tft.drawString(200,200,LED,WHITE);. It says invalid conversion "INT" to "CHAR". Can some one help I wanna display a sensor value but as well still be able to Choose color, X,Y Placement, and Rotation. Thanks
Here is the .h file I am working with...
// Graphics library by ladyada/adafruit
// MIT license
#define	BLACK           0x0000
#define    BLUE           0x001F
#define    RED             0xF800
#define    GREEN         0x07E0
#define    CYAN           0x07FF
#define    MAGENTA     0xF81F
#define    YELLOW       0xFFE0
#define    WHITE         0xFFFF
#define swap(a, b) { uint16_t t = a; a = b; b = t; }
#include <WProgram.h>
#define ST7735_NOP 0x0
#define ST7735_SWRESET 0x01
#define ST7735_RDDID 0x04
#define ST7735_RDDST 0x09
#define ST7735_SLPIN  0x10
#define ST7735_SLPOUT  0x11
#define ST7735_PTLON  0x12
#define ST7735_NORON  0x13
#define ST7735_INVOFF 0x20
#define ST7735_INVON 0x21
#define ST7735_DISPOFF 0x28
#define ST7735_DISPON 0x29
#define ST7735_CASET 0x2A
#define ST7735_RASET 0x2B
#define ST7735_RAMWR 0x2C
#define ST7735_RAMRD 0x2E
#define ST7735_COLMOD 0x3A
#define ST7735_MADCTL 0x36
#define ST7735_FRMCTR1 0xB1
#define ST7735_FRMCTR2 0xB2
#define ST7735_FRMCTR3 0xB3
#define ST7735_INVCTR 0xB4
#define ST7735_DISSET5 0xB6
#define ST7735_PWCTR1 0xC0
#define ST7735_PWCTR2 0xC1
#define ST7735_PWCTR3 0xC2
#define ST7735_PWCTR4 0xC3
#define ST7735_PWCTR5 0xC4
#define ST7735_VMCTR1 0xC5
#define ST7735_RDID1 0xDA
#define ST7735_RDID2 0xDB
#define ST7735_RDID3 0xDC
#define ST7735_RDID4 0xDD
#define ST7735_PWCTR6 0xFC
#define ST7735_GMCTRP1 0xE0
#define ST7735_GMCTRN1 0xE1
class ST7735 {
 public:
  ST7735(uint8_t CS, uint8_t RS, uint8_t SID,
	 uint8_t SCLK, uint8_t RST);
  ST7735(uint8_t CS, uint8_t RS, uint8_t RST);
  void initB(void);
  void initR(void);
  // drawing primitives!
  void pushColor(uint16_t color);
  void drawPixel(uint8_t x, uint8_t y, uint16_t color);
  void drawLine(int16_t x, int16_t y, int16_t x1, int16_t y1, uint16_t color);
  void fillScreen(uint16_t color);
  void drawVerticalLine(uint8_t x0, uint8_t y0,
			uint8_t length, uint16_t color);
  void drawHorizontalLine(uint8_t x0, uint8_t y0,
  void drawFastLine(uint8_t x0, uint8_t y0, uint8_t l,
		    uint16_t color, uint8_t flag);
  void drawRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h,
		uint16_t color);
  void fillRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h,
		uint16_t color);
  void drawCircle(uint8_t x0, uint8_t y0, uint8_t r,
		  uint16_t color);
  void fillCircle(uint8_t x0, uint8_t y0, uint8_t r,
		  uint16_t color);
  void drawString(uint8_t x, uint8_t y, char *c,
		  uint16_t color, uint8_t size=1);
  void drawChar(uint8_t x, uint8_t y, char c,
  static const uint8_t width = 128;
  static const uint8_t height = 160;
  void setAddrWindow(uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1);
  void setRotation(uint8_t);
  uint8_t getRotation(void);
  void dummyclock(void);
  void writecommand(uint8_t);
  void writedata(uint8_t);
  // these are not for use, 8-bit protocol only!
  uint8_t readdata(void);
  uint8_t readcommand8(uint8_t);
  uint16_t readcommand16(uint8_t);
  uint32_t readcommand32(uint8_t);
 private:
  void spiwrite(uint8_t);
  //uint8_t spiread(void);
  uint8_t _cs, _rs, _rst, _sid, _sclk;
  uint8_t csport, rsport, sidport, sclkport;
  uint8_t cspin, rspin, sidpin, sclkpin;
  uint8_t madctl;
its strange, try using an uint8_t inplace of the char to see if still the error is there are you sure the INT or CHAR you are referring to isnt a pointer etc?
Is LED an integer or a string? That function is asking for a string(char*) not an integer.
Use sprintf() to make the value of LED into a string. Or you can make your own function that does it for you.
Its not strange at all. If you looked at the class provided, the function is clearly asking for a char* and not a uint8_t.
I didnt look at it as I wanted just the excerpt of the code where the problems are and not the whole code,
the line at which the error is should be pointed out.
