Documents/Arduino/libraries/LCDKeypad/LCDKeypad.cpp:5:10: error: #include expects "FILENAME" or <FILENAME>
#include “Arduino.h”
Documents/Arduino/libraries/LCDKeypad/LCDKeypad.cpp: In member function 'int LCDKeypad::button()':
Documents/Arduino/libraries/LCDKeypad/LCDKeypad.cpp:22:21: error: 'analogRead' was not declared in this scope
input=analogRead(0);
This is the code I am trying to run from a library example:
#include <LiquidCrystal.h>
#include <LCDKeypad.h>
#define MINVAL 1
#define MAXVAL 1000
LCDKeypad lcd;
byte c_up[8] = {
B00100,
B01110,
B10101,
B00100,
B00100,
B00100,
B00100,
B00100,
byte c_down[8] = {
B00100,
B00100,
B00100,
B00100,
B00100,
B10101,
B01110,
B00100,
byte c_select[8] = {
B00000,
B01110,
B11111,
B11111,
B11111,
B11111,
B01110,
B00000,
int i,k;
lcd.createChar(1,c_select);
lcd.createChar(2,c_up);
lcd.createChar(3,c_down);
lcd.begin(16, 2);
lcd.clear();
lcd.print(" Guess");
lcd.setCursor(0,1);
lcd.print(" The Number");
delay(3000);
for (k=0;k<3;k++)
lcd.scrollDisplayLeft();
delay(200);
for (i=0;i<3;i++)
for (k=0;k<6;k++)
lcd.scrollDisplayRight();
delay(200);
for (k=0;k<6;k++)
delay(200);
for (k=0;k<16;k++)
delay(200);
int bottom=MINVAL, top=MAXVAL;
int trynumber=0;
int guess, buttonPressed;
lcd.clear();
lcd.print("Make up a number");
lcd.setCursor(0,1);
lcd.print("from ");
lcd.print(MINVAL,DEC);
lcd.print(" to ");
lcd.print(MAXVAL,DEC);
lcd.print(" ");
waitButton();
waitReleaseButton();
do
lcd.clear();
guess=bottom+(top-bottom)/2;
trynumber++;
lcd.print("Is it ");
lcd.print(guess,DEC);
lcd.print("?");
lcd.setCursor(0,1);
lcd.write(1);
lcd.write(' ');
lcd.write(2);
lcd.write(' ');
lcd.write(3);
lcd.write(' ');
do
buttonPressed=waitButton();
while(!(buttonPressed==KEYPAD_SELECT || buttonPressed==KEYPAD_UP || buttonPressed==KEYPAD_DOWN));
lcd.setCursor(0,1);
lcd.write(buttonPressed==KEYPAD_SELECT?1:' ');
lcd.write(' ');
lcd.write(buttonPressed==KEYPAD_UP?2:' ');
lcd.write(' ');
lcd.write(buttonPressed==KEYPAD_DOWN?3:' ');
delay(100);
if (buttonPressed==KEYPAD_UP)
bottom=constrain(guess+1,MINVAL,top);
else if (buttonPressed==KEYPAD_DOWN)
top=constrain(guess-1,bottom,MAXVAL);
while (buttonPressed!=KEYPAD_SELECT && top!=bottom);
lcd.clear();
if (top==bottom)
lcd.print("It must be ");
guess=top;
lcd.print("It is ");
lcd.print("!");
lcd.setCursor(0,1);
lcd.print("Tries: ");
lcd.print(trynumber,DEC);
lcd.print(" ");
waitButton();
int waitButton()
int buttonPressed;
lcd.blink();
while((buttonPressed=lcd.button())==KEYPAD_NONE)
delay(50);
lcd.noBlink();
return buttonPressed;
void waitReleaseButton()
delay(50);
while(lcd.button()!=KEYPAD_NONE)
delay(50);
I have now installed libraries manually however the 'Filename' message is where I am stuck. I have changed the include name to <Arduino.h> in my .cpp file as this was a suggestion in other threads.
