SainSmart 2.8" TFT 240x320 and Mega 2560
I am trying to get a SainSmart 2.8 TFT Touchscreen working on a Mege2560 with out the shield.
I have connected the display following the pinout examples in this post
Link to the display on the SS site
I am loading the sketch UTFT_Demo_320x240 example form the UTFT library.
I have changed the model to CTE28 and/or TFT01_28 and get the following results:
The Sketch compiles and uploads fine, but the screen is solid white.
When I re-upload or press the reset button I see the desired displayed graphic for a second then once the mega boots up the display is solid white screen again.
I must have something wrong but I am not sure what.
I know the Mega is communicating with the TFT because the display is there on reset, I am guessing I have something wrong on the power side of the connection but I am not sure what it could be.
I am hoping that someone knows what I have connected wrong based on what changes on restart of the mega.
Thanks in advance for any help you can give
I had the same issue with the Sainsmart 2.4" display.
Here is what I used to get it working.
UTFT myGLCD(ILI9325C,38,39,40,41); UTouch myTouch(6,5,4,3,2);
Use the pin numbers of how you have your wired.
The key for me was the: ILI9325C parameter.
Good luck!
Thanks casey-ryback for the help.
I got my issue solved but did not have time to post, my solution was a wiring problem.
It is working now and I am on to the next phase of the project.
