Sainsmart 3.2" Touch + MEGA SDRaw issue: ArduinoOutStream' does not name a type
Hello,
when I try to run the SDRaw 320*240 example I`m always getting two error messages:
cout' was not declared in this scope
got no clue how to fix that.
The SDStream.h is already commented out.
Can anybody help?
Thanks
You are asking a programming question without posting your code...
The error messages could be caused by the following:
Library is not installed
Library is installed in the wrong location
Library folders are named wrong
But it could also be that you have commented out the line the IDE uses to read that library..
its mostly the standard libraries. I downloaded the specific ones and included them in the IDE. The compiler doesnt tell about missing files.
The class ArduinoOutStream is defined in Arduinostream.h and this is found by the compiler:
#include <SPI.h>
// SdFat lib from here :-
// https://github.com/greiman/SdFat/archive/master.zip
#include <SdFat.h>
//#include <SdStream.h>
#include <UTFT.h>
#include <ITDB02_Touch.h>
#include <UTFT_Buttons_ITDB.h>
#include <UTFT_SdRaw.h>
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
#define SD_CHIP_SELECT  53  // SD chip select pin
// file system object
SdFat sd;
// print stream
ArduinoOutStream cout(Serial);
int wait = 2, pressed_button;
// Initialize display
// Set the pins to the correct ones for your development board
// Standard Arduino Uno/2009 Shield            : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due       : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board                   : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(SSD1289, 38, 39, 40, 41);
// Initialize touchscreen
// Standard Arduino Uno/2009 Shield            : 15,10,14, 9, 8
// Standard Arduino Mega/Due shield            :  6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due       :  6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due (JP10):  6, 5,32, 3, 2
// Teensy 3.x TFT Test Board                   : 26,31,27,28,29
// ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
ITDB02_Touch  myTouch( 6, 5, 4, 3, 2);
UTFT_SdRaw myFiles(&myGLCD);
UTFT_Buttons  myButtons(&myGLCD, &myTouch);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println(F("Initialising SD card..."));
  bool mysd = 0;
  // see if the card is present and can be initialized:
  while (!mysd)
    if (!sd.begin(SD_CHIP_SELECT, SPI_FULL_SPEED)) {
      Serial.println(F("Card failed, or not present"));
      Serial.println(F("Retrying...."));
      mysd = 1;
      Serial.println(F("Card initialised."));
  Serial.println(F("Initialising LCD."));
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch(LANDSCAPE);
  myTouch.setPrecision(PREC_MEDIUM);
  myButtons.setTextFont(BigFont);
  int butskip = myButtons.addButton( 85,  219 , 70,  20, "Skip");
  Serial.println(F("LCD initialised."));
  //             Wait for GPS screen  or skip button
  Serial.println(F("Initialising GPS."));
  long mytime = millis();
  myFiles.load(0, 0, 240, 240, "wait4gps.RAW", 1 , 1);
  long mytime1 = millis() - mytime;
  cout << F("Time to draw 240x240 raw ") << mytime1 << F(" ms") << endl;
  myButtons.drawButton(butskip);
  while (wait == 2) {
    pressed_button = myButtons.checkButtons();
    if (pressed_button == butskip)
      cout << F("Skip button detected (No GPS :( )\n");
      wait = true;
  char fname240[] = "SK45/SK400500.RAW";
  myGLCD.clrScr();
  mytime = millis();
  myFiles.load(0, 0, 240, 240, fname240, 1);
  cout << F("Time to draw 240x240 raw (no extra buffer) (non inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  mytime = millis();
  myFiles.load(0, 0, 240, 240, fname240, 8, 1);
  cout << F("Time to draw 240x240 raw (8*buffer) (inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  mytime = millis();
  myFiles.pan(0, 0, 240, 240, 0, 0, 4040, 4040, "SK45/SK45.RAW");
  cout << F("Time to draw 240x240 portion from 4040x4040 raw image (non inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  mytime = millis();
  myFiles.pan(0, 0, 240, 240, 0, 0, 4040, 4040, "SK45/SK45.RAW", 1);
  cout << F("Time to draw 240x240 portion from 4040x4040 raw image (inverted colour) ") << mytime1 << F(" ms") << endl;
  delay(5000);
  myGLCD.clrScr();
  int xad, yad;
  int tmpx = 0, tmpy = 0;
  for (int yx = 0; yx < 6; yx++)
    int xd = 0, yd = 0;
    mytime = millis();
    for (int z = 0 + (yx * 35); z < 35 + (yx * 35); z++)
      tmpy = (z / 22);
      tmpx = z - (tmpy * 22);
      yad = (tmpy * 69) + 10;
      xad = (tmpx * 108) + 44;
      myFiles.pan(xd, yd, 42, 42, xad, yad, 2374, 696, "icons.raw");
      xd += 42;
      if (xd > 277)
        xd = 0;
        yd += 42;
    mytime1 = millis();
    cout << F("Time to draw 35 42x42 icons (") << (0 + (yx * 35)) << "-" << (34 + (yx * 35)) << F(") from 2374x696 image ") << (mytime1 - mytime) << F(" ms") << endl;
    delay(5000);
  cout << F("Thanks for watching!") << endl;
  myGLCD.clrScr();
  myGLCD.setFont(BigFont);
  myGLCD.setColor(VGA_GREEN);
  myGLCD.print("Thanks for watching!", CENTER, 111);
What I dont understand is - how can "cout" be an instance of a class, since its a standard function?
see also the Header file:
class ArduinoOutStream : public ostream {
 public:
  /** constructor
   * \param[in] pr Print object for this ArduinoOutStream.
  explicit ArduinoOutStream(Print& pr) : m_pr(&pr) {}
 protected:
  /// @cond SHOW_PROTECTED
   * Internal do not use
   * \param[in] c
  void putch(char c) {
    if (c == '\n') {
      m_pr->write('\r');
    m_pr->write(c);
  void putstr(const char* str) {
    m_pr->write(str);
  bool seekoff(off_type off, seekdir way) {
    return false;
  bool seekpos(pos_type pos) {
    return false;
  bool sync() {
    return true;
  pos_type tellpos() {
    return 0;
  /// @endcond
 private:
  ArduinoOutStream() {}
  Print* m_pr;
#endif  // ENABLE_ARDUINO_FEATURES
#endif  // ArduinoStream_h
Thanks
Eddie
SdRaw_320x240.cpp (5.17 KB)
ArduinoStream.h (3.16 KB)
I have no idea what you based this erroneous conclusion on. cout IS an instance of the iostream class. It is NOT a "standard function", whatever that is supposed to mean.
Maybe I should say it more precisely.
COUT is actually an instance of the iostream class.
But it looks like the code tries to generate an instance of the ArduinoOutStream class with the same name: COUT.
So how can this work?
Br,
Simple. There is no default implementation of cout. So, anyone can create an instance of any class, and call the instance cout. Nothing magical about it.
The "standard" cout is in the std namespace. In order to use the "standard" cout instance, you need a using std::cout; statement, a using namespace std; statement, or you need to use std::cout.
Using the entire namespace is a moronic move, in my opinion. So, the only real choices are to use the fully qualified name or to add a using statement to the code - neither of which happens automagically. In any development system (that I would consider using).
