SainSmart 8-Channel Relay Module/Fritzing
Anyone have a fritzing schematic, for a SainSmart 8-Channel Relay Module
It would make my life easier, as I'm new to it, and haven't figured out how to make parts yet.
Thanks
Are you struggling to understand how to connect the relay board to your arduino
OR
Are you trying to build a clone of the 8 channel relay sheild?
No everything works fine, I'm trying to make a Schematic of what I did.
I actually need the 5v 4 relay on fritzing, all the relays i find aren't what i need. Anyone know where i can get it? :disappointed_relieved: :disappointed_relieved: :disappointed_relieved: :disappointed_relieved: :disappointed_relieved:
Hi if you are making a schematic, then fritzing is not a schematic.
It is a pictorial/graphic method to show how to physically connect components.
A schematic is totally different and surprisingly easier diagram to read.
Especially when close connections are concerned, because a proper circuit diagram is not to scale, like fritzing, you can space components and their connections to make them readable.
Tom... :slight_smile:
Google "Express PCB" , good simple CAD program that is free, that is does not have ads, time limit or email spam associated with it.
PCB Express does have an easy to learn editor. The problem is, it is not transportable. You would be better off learning how to use Eagle-lite. I did it the long way by learning PCB Express first, then had to redraw much of my stuff that I wanted to share.
Tom, you can do rudimentary schematics in Fritzing...probably good enough for beginners. It will even schem your drawing for you IIRC.
-fab
