I have a Sainsmart LCD2004 with 20x4 display.
I've removed the LiquidCrystal library that came with my arduino software, and installed instead fmalpartida's new-liquidcrystal library.
I have an Arduino Uno R3, and I connected the LCD2004's VCC to Uno 5V, LCD GND to Uno GND, LCD SDA to Uno A4, LCD SCL to Uno A5.
I tried running this code:
** Example Arduino sketch for SainSmart I2C LCD2004 adapter for HD44780 LCD screens
** Readily found on eBay or http://www.sainsmart.com/
** The LCD2004 module appears to be identical to one marketed by YwRobot
** Address pins 0,1 & 2 are all permenantly tied high so the address is fixed at 0x27
** Written for and tested with Arduino 1.0
** This example uses F Malpartida's NewLiquidCrystal library. Obtain from:
** https://bitbucket.org/fmalpartida/new-liquidcrystal
** Edward Comer
** LICENSE: GNU General Public License, version 3 (GPL-3.0)
** NOTE: TEsted on Arduino NANO whose I2C pins are A4==SDA, A5==SCL
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR 0x27 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
int n = 1;
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
lcd.begin (20,4);
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(LOW);
lcd.home (); // go home
lcd.print("SainSmart I2C tester");
lcd.setCursor ( 0, 1 ); // go to the 2nd line
lcd.print("F Malpartida library");
lcd.setCursor ( 0, 2 ); // go to the third line
lcd.print("Test & demonstration");
lcd.setCursor ( 0, 3 ); // go to the fourth line
lcd.print("Iteration No: ");
// Backlight on/off every 3 seconds
lcd.setCursor (14,3); // go col 14 of line 3
lcd.print(n++,DEC);
lcd.setBacklight(LOW); // Backlight off
delay(3000);
lcd.setBacklight(HIGH); // Backlight on
delay(3000);
And nothing happens at all. (The backlight is on once I connect VCC and GND, but the display never changes - it just looks like this:
I'm clearly missing something simple... what do I do?
Thanks!
