SainSmart self balancing robot goes in circle
Hello all, My boy and I have been building a SainSmart balancing bot. I do not have the whole kit but I have bought the shield and the V.3 motors with encoders. The bot balances but goes in tight circles. I believe there should be an offset some where in the code to fix this but I am not finding it. also is there a place on the web that really explains how to implement this bot? I have done quite a bit of research and have not found a lot of good information on this build.
#include <Wire.h>
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
#include <I2Cdev.h>
#include <MPU6050.h>
MPU6050 accelgyro;
MPU6050 initialize;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define Gry_offset 0  //The offset of the gyro
#define Gyr_Gain 131
#define Angle_offset 0  // The offset of the accelerator
#define RMotor_offset -20  // The offset of the Motor
#define LMotor_offset 60  // The offset of the Motor
#define pi 3.14159
float Angle_Delta, Angle_Recursive, Angle_Confidence;
float kp, ki, kd;
float Angle_Raw, Angle_Filtered, omega, dt;
float Turn_Speed = 0, Run_Speed = 0;
float LOutput, ROutput, Input, Output;
unsigned long preTime, lastTime;
float errSum, dErr, error, lastErr;
int timeChange;
float Sum_Right, Sum_Right_Temp, Sum_Left, Sum_Left_Temp, Distance, Distance_Right, Distance_Left, Speed;
int TN1 = 23;
int TN2 = 22;
int ENA = 5;
int TN3 = 24;
int TN4 = 25;
int ENB = 4;
struct Axis  // Datas from remote control
  uint16_t axis_1;
  uint16_t axis_2;
  uint16_t axis_3;
  uint16_t axis_4;
  uint16_t axis_5;
  uint16_t axis_6;
  uint16_t axis_7;
  uint16_t axis_8;
Axis axis_x;
struct Gesture  // Datas send back to remote control
  float angle;
  float omega;
  int speed;
  uint16_t P;
  uint16_t I;
  uint16_t D;
  uint16_t null_1;
  uint16_t null_2;
Gesture data;
  Wire.begin();
  TCCR3A = _BV(COM3A1) | _BV(WGM31) | _BV(WGM30); // TIMER_3 @1K Hz, fast pwm
  TCCR3B = _BV(CS31);
  TCCR0A = _BV(COM0B1) | _BV(WGM01) | _BV(WGM00); // TIMER_0 @1K Hz, fast pwm
  TCCR0B = _BV(CS01) | _BV(CS00);
  /* If the robot was turned on with the angle over 45(-45) degrees,the wheels
   will not spin until the robot is in right position. */
  accelgyro.initialize();
  for (int i = 0; i < 200; i++) // Looping 200 times to get the real gesture when starting
    Filter();
  if (abs(Angle_Filtered) < 45)  // Start to work after cleaning data
    omega = Angle_Raw = Angle_Filtered = 0;
    Output = error = errSum = dErr = 0;
    Filter();
    myPID();
  pinMode(TN1, OUTPUT);
  pinMode(TN2, OUTPUT);
  pinMode(TN3, OUTPUT);
  pinMode(TN4, OUTPUT);
  pinMode(ENA, OUTPUT);
  pinMode(ENB, OUTPUT);
  pinMode(18, INPUT);
  pinMode(2, INPUT);
  attachInterrupt(4, State_A, FALLING);
  attachInterrupt(1, State_B, FALLING);
  // 24L01 initialization
  Mirf.cePin = 53;
  Mirf.csnPin = 48;
  Mirf.spi = &MirfHardwareSpi;
  Mirf.init();
  Mirf.setRADDR((byte *)"clie1");
  Mirf.payload = 16;
  Mirf.config();
  while (1)
    Recive();
    Filter();
    if ((micros() - lastTime) > 10000)
      // If angle > 45 or < -45 then stop the robot
        myPID();
        PWMControl();
        digitalWrite(TN1, HIGH);
        digitalWrite(TN2, HIGH);
        digitalWrite(TN3, HIGH);
        digitalWrite(TN4, HIGH);
      lastTime = micros();
void Recive()
  if (!Mirf.isSending() && Mirf.dataReady())
    // Read datas from the romote controller
    Mirf.getData((byte *) &axis_x);
    Serial.print("axis_1=");
    Serial.print(axis_x.axis_1);
    Serial.print("  axis_2=");
    Serial.print(axis_x.axis_2);
    Serial.print("  axis_3=");
    Serial.print(axis_x.axis_3);
    Serial.print("  axis_4=");
    Serial.print(axis_x.axis_4);
    Serial.print("  axis_5=");
    Serial.print(axis_x.axis_5);
    Serial.print("  axis_6=");
    Serial.print(axis_x.axis_6);
    Serial.print("  axis_7=");
    Serial.print(axis_x.axis_7);
    Serial.print("  axis_8=");
    Serial.println(axis_x.axis_8);
    Mirf.setTADDR((byte *)"clie1");
    Mirf.send((byte *) &data);  // Send datas back to the controller
    if (axis_x.axis_1 >= 520) // Y axis datas from joystick_1
      Turn_Speed = map(axis_x.axis_1, 520, 1023, 0, 120);
    else if (axis_x.axis_1 <= 480)
      Turn_Speed = map(axis_x.axis_1, 480 , 0, 0, -120);
      Turn_Speed = 0;
    if (axis_x.axis_4 >= 520) // X axis datas from joystick_2
      Run_Speed = map(axis_x.axis_4, 520, 1023, 0, 100);
    else if (axis_x.axis_4 <= 480)
      Run_Speed = map(axis_x.axis_4, 480, 0, 0, -100);
      Run_Speed = 0;
    axis_x.axis_1 = axis_x.axis_4 = 500;
  data.omega = omega;
  data.angle = Angle_Filtered;
  data.speed = Sum_Right;
  data.P = analogRead(A0);
  data.I = analogRead(A1);
  data.D = analogRead(A2);
void Filter()
  // Raw datas
  accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
  Angle_Raw = (atan2(ay, az) * 180 / pi + Angle_offset);
  omega = gx / Gyr_Gain + Gry_offset;
  // Filter datas to get the real gesture
  unsigned long now = micros();
  timeChange = now - preTime;
  preTime = now;
  dt = timeChange * 0.000001;
  Angle_Delta = (Angle_Raw - Angle_Filtered) * 0.64;
  Angle_Recursive = Angle_Delta * dt + Angle_Recursive;
  Angle_Confidence = Angle_Recursive + (Angle_Raw - Angle_Filtered) * 1.6 + omega;
  Angle_Filtered = Angle_Confidence * dt + Angle_Filtered;
  Serial.println(Angle_Filtered);
void myPID()
  kp = 26.000;
  ki = 0;
  kd = 2.6;
  // Calculating the output values using the gesture values and the PID values.
  error = Angle_Filtered;
  errSum += error;
  dErr = error - lastErr;
  Output = kp * error + ki * errSum + kd * omega;
  lastErr = error;
  noInterrupts();
  Sum_Right = (Sum_Right + Sum_Right_Temp) / 2;
  Sum_Left = (Sum_Left + Sum_Left_Temp) / 2;
  Speed = (Sum_Right + Sum_Left) / 2;
  Distance += Speed + Run_Speed;
  Distance = constrain(Distance, -300, 300);
  Output += Speed * 70 + Distance * 0.6;
  Sum_Right_Temp = Sum_Right;
  Sum_Left_Temp = Sum_Right;
  Sum_Right = 0;
  Sum_Left = 0;
  ROutput = Output + Turn_Speed;
  LOutput = Output - Turn_Speed;
  interrupts();
void PWMControl()
  if (LOutput > 0)
    digitalWrite(TN2, LOW);
  else if (LOutput < 0)
    digitalWrite(TN1, LOW);
    OCR3A = 0;
  if (ROutput > 0)
    digitalWrite(TN4, LOW);
  else if (ROutput < 0)
    digitalWrite(TN3, LOW);
    OCR0B = 0;
  OCR3A = min(1023, (abs(LOutput * 4) + LMotor_offset * 4)); // Timer/Counter3 is a general purpose 16-bit Timer/Counter module
  OCR0B = min(255, (abs(ROutput) + RMotor_offset)); // Timer/Counter0 is a general purpose 8-bit Timer/Counter module
void State_A()
  if (digitalRead(18))
    Sum_Right ++;
    Sum_Right --;
void State_B()
  if (!digitalRead(2))
    Sum_Left ++;
    Sum_Left --;
Ok I looked into this a little more and found this piece of code below. Does any one have any insight on why they programmed the right and left motor differently? I do not believe this is the answer to my circles problem but I found it interesting.
Two seemingly identical, brushed DC motors usually won't run at the same speeds, even though all other conditions are the same.
In the above example, the (R/L)Motor_offset variables are probably set somewhere else in the code, after the author did some experimenting, to make the motors run at the same speed.
Note: in the above example, the factor of 4 takes into account that one timer is 16 bits and the other is 8 bits. It is irrelevant to this discussion.
weldsmith:
[/quote]
It's the part that says :
At the moment, it .... it appears that one motor might have a tendency to move in one direction, while the other one is biased to move in the opposite direction, which might explain the spinning motion.
Try setting both motors to the same 'sign', and see what happens.... eg -20 for one and -25 for the other. Or +20 and +20.
0 and 0 would be good initial offset choices.
It's ok to try 0 and 0 to begin with, even though a little bit is usually added, like 20 and 20 to overcome dead-zone.
Jremington/Southpark thanks for the reply.
The offsets are not at zero because I had already tried many different offsets. maybe I need to go big like 200 or more.
Both motors are going in the right direction just one is considerably faster. I thought I might have a bad motor driver.
Southpark, I saw a recent post of yours on this bot kit. I could not agree more, it has some flaws. Do you know of a dedicated forum for this bot. the documentation for the board is quite sketchy.
Could be, or the gear train is binding on one side.
Test by disconnecting both motors from the drivers, suspend the bot so that the wheels don't touch the ground, and use batteries or a variable power supply to apply different voltages directly to each of the motor terminals. Check that the two wheels have similar RPMs at similar motor voltages.
