Hi all. Having some problems with a sainsmart LCD (as i have seen so are quite a few people), a little different to the usual though.
I'm familiar with the Arduino environment but can't figure this one out.
For a small project i'm undertaking i'm using an interrupt to to count the number of revolutions of a wheel and then calculating the speed and wanting to then output this to an lcd display on a small go kart.
i've managed to get this to read into the serial monitor correctly, and set up the display so that it will output some text using I2C and help from http://arduino-info.wikispaces.com/LCD-Blue-I2C .
I am using arduino 1.0.5 and have tried both arduino unoR3 and Mega2560
The Problem:
I have so far been unable to get the display to then output the calculated value, it appears to output everything initially (so that it says the speed is 0) and then no longer update the display.
I have tried multiple methods to this including creating a function for the updating display, no longer writing the result to serial (to view in serial monitor), as well as creating a function to calculate the speed instead of lines of code in a loop. I've rearranged the order in which the functions are called.
Help on this matter would be greatly appreciated (i'm sure its just something simply i've missed). Hopefully i've explained it well enough. :S
The code:
#include <LCD.h>
#include <LiquidCrystal.h>
#include <Wire.h>
////////initialise pins//////////////
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
const int ButtonPin = 3; // microswitch speedo pin
////// LCD Setup //////////
#define I2C_ADDR 0x3F // Define I2C Address where the PCF8574A is
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
////////Variable Defining///////
int Speed=0;
int KartSpeed;
double MaxSpeed=0;
int Calc;
int FuelRate=0;
volatile int NbTopsSwitch = LOW;
//////Initialise Serial////
//////PinSetup/////////
pinMode(ButtonPin, INPUT);
////////LCD Setup////////
lcd.begin (20,4);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
///////Attach Interrupts//////////////
attachInterrupt (1, buttonhigh, RISING); //and the interrupt is attached to trigger on the rising edge of the switch press
/////// Call the display function///////
updatedisplay();
////////// Call the Speed Calc Function
SpeedCalc();
////// Update display function///////
void updatedisplay()
lcd.clear(); // clear everything from the LCD
lcd.home (); // go home
lcd.print("Speed =");
lcd.setCursor(11,0); // set cursor to 11th column on line 1
lcd.print(Speed);
lcd.setCursor(0,1); // set cursor to 1st column on line 2
lcd.print("MaxSpeed = MPH");
lcd.setCursor(11,1); // set cursor to 11th column on line 2
lcd.print(MaxSpeed);
lcd.setCursor(0,2); // set cursor to 1st column on line 3
lcd.print("EngineTemp = oC");
lcd.setCursor(0,3); // set cursor to 1st column on line 4
lcd.print("FuelFlow = LPH");
lcd.setCursor(11,3); // set cursor to 11h column on line 4
lcd.print(FuelRate);
//////Speed calc Function
void SpeedCalc()
NbTopsSwitch = 0; //Set NbTops to 0 ready for calculations
sei(); //Enables interrupts
delay (1000); //Wait 1 second
cli(); //Disable interrupts
Speed = ((NbTopsSwitch/19588.3)*3600); // speed is the number of revolutions in one second (determined by nbTopsSwitch)
// Divided by the number of revolutions in a mile
// multiplied by the number of seconds in an hour to give MPH
Serial.print (Speed, DEC); //Prints the number calculated above
Serial.print (" MPH\r\n"); //Prints "MPH" and returns a new line
//////Called Interrupt///////
void buttonhigh()
NbTopsSwitch++; ////count the rising and falling edge of the switch pulse
..... Code Adapted from http://arduino-info.wikispaces.com/LCD-Blue-I2C, and http://www.seeedstudio.com/wiki/G3/4_Water_Flow_sensor.
I have attached images of the back of the LCD, what i get as an output, the sensor shield i'm using and reading in a speed to the serial monitor compared to the display.
