Salvaged LCD from pen-clock
Hi !
I'm new to this forum. I hope you will be able to help me :slight_smile:
I'm trying to use a small LCD from a pen clock (around 0.70€) :
My goal : drive it with an Arduino (or another AVR) to use at least 2 digits.
I opened it and checked the PCB :
There is 13 connectors on the LCD.
The battery is a 1.5V button battery.
I soldered a wire on each LCD connector :
I tried to look at the signals on each wire (I do not have an expensive oscilloscope (it's a DSO138).
It seems that the LCD is multiplexed, with two commons (one on the left, one on the right).
Common signal :
Segment signal :
It seems quite near some explanations I found here :
http://mail.rsgc.on.ca/~cdarcy/Datasheets/lcd_apnt.pdf
But my problem is that the signals are between Vss and Vcc, with Vss = -1V and Vcc = 1.5V.
How can a produce such a signal with the output of an Arduino ?
On the PDF file, they are using Vss = GND, which is not my case.
Do you see any other problem that I can encounter ?
Thank you for your help,
Jean-Matthieu
You have probably solved your problem by now, but here is the solution:
You can create an AC with three levels of positive DC voltages to drive these LCDs.
V1 = 0V DC
V2 = 1.5V DC
V3 = 3V DC
You can alternate among these voltage levels.
Please read “Zilog’s Direct Drive of LCD Displays” pgs. 2-3.
Or you can use an H-Bridge to create the AC.
Oh, by the way, forgot to say.. You should have an AC around 25-30HZ to drive these LCDs. Below frequencies will produce visible flickering. And above frequencies will increase power consumption and shorten the life of the LCD.
