Salvaging components from an alarm clock
I'm currently working on an alarm clock project. I want to create an alarm clock that cannot be forced off and does not have a snooze feature. I'll be prototyping it with the Arduino but would like the final project to run on a standalone Atmel chip. I decided to take apart my old (but functioning) alarm clock to check it out and see if I could possibly salvage some components and/or reuse the housing for my project.
I've attached a picture of the alarm clock.
Buttons:
The buttons are rounded bulges that 'pop' down when pressed like the safety feature on a lid of a jar after it's been opened. There are 6 wires and 6 buttons ('snooze' has 2 buttons beneath it). What is the name of this variety of button ? Why doesn't it require at least one extra wire for either voltage or ground? How would I go about using this?
Speaker:
What is the name of this type of speaker? I don't think it's a piezo speaker but I'm not entirely sure. Since it's glued in there pretty tightly I'd like to just leave it and use it for my project, if possible.
7 Segment Display:
Would there be a relatively painless way to reverse engineer this thing? It is the perfect size and could be mounted easily in the housing. I already have a 7-Segment display and although it's much smaller, it costs only $2, requires half the pins, and has proper documentation. Plus I have already learned how to use it. Not sure if reverse engineering the alarm clock display would be worth the frustration.
duinodudes:
Buttons:
Snooze buttons are wired in parallel so same wire needed for both. This leaves you a spare wire probably for GND.
Speaker:
It is a piezo disk.
7 Segment Display:
Depends on what your pain threshold is :smiling_imp: Also the code for driving it will be a lot more complex as you will probably need to do multiplexing to get a usable display of numbers.
