Sam3x8e upload but not working
Hi everyone,
I am design my pcb board for my job. I use Arduino Due devolop my code and ıt worked.After we design new pcb board and I used only Sam3x8e and default component(Crystal,cap,res...). I upload code to Sam3x8e using atmega16u2. After Arduino all pins show 3,3V(high) and not run program.
Anyone know what is the problem
Thanks
atmelsamba:
Your personal pcb.
Yes ıts my personal pcb
atmelsamba:
And there is your answer.
(deleted)
spycatcher2k:
Here is a hint :
POST YOUR SCHEMATIC AND LAYOUT - we are not frikin mind readers.
And is it really our "job" to help him debug a custom pcb ? ? ?
According to him the Arduino Due he has works just fine.
Arduino due works fine.After I draw new pcb and use sam3x8e and its default component,upload program.But it not working and always all pins high
ieee488:
help him a commercial venture
aarg:
a commercial venture, you say
I am out!
ieee488:
I am out!
I am sure about pcb , i want to say that Maybe Anyone know what is problem about sam3x8e.Maybe bootloader, maybe any pins
Thanks
(deleted)
I dont understand what is happen.I am try to answer your question.I am sorry
atmelsamba:
Other than vague speculations about what might be wrong, you haven't provided any information about your project.
Look closely at reply #4.
its schmatic
And you've buzzed out the board and are happy its the same as the schematic? That alone is a lot of work,
but sometimes necessary commissioning a new PCB.
You did a close visual inspection?
You double checked absolutely every part of the schematic against a the Due design? It only takes
one tiny mistake to break things...
This is stuff only you can do I think, you have the actual board.
The bootloader is hard-programmed into the SAM chip, that shouldn't be an issue.
Hi Markt,
I did close visual inspection but it still not working
Ops circuit;
Should the gate to the erase MOSFET be open circuit?
Tom.. :slight_smile:
Hi TomGeorge,
it should be like this?
Your erase MOSFET
DUO Erase MOSFET
Can you tell us your electronics, programming, Arduino, hardware experience?
It is a basic step to not leave a MOSFET gate open circuit.
Tom... :slight_smile:
