Hello:
Writing code using the hookup guide for the "SparkFun SAMD21 Mimi Breakout" board seems to be straight forward and easy, however when the code is loaded to flicker LEDs it shows up (appears) in the list of available components only as a faded out lined text and is not available to use. The SAMD21 LEDs blink by themselves just because it is hooked up to the USB cable. I thought the code would be available but you all know what happens with faded code in any program. The wiring on the boards should be correct and the drivers were loaded as per directions. Why the Fade away?
James
Which code are you looking at?
Is it the code that is "faded" (can be caused by being commented out, or because of "use external editor" preference), or the "board" selection (might be fixed by double-tap on the reset.)
Shannon: I am having problems with this email. Is the attachment working?
SAMD21122617B.txt (1.32 KB)
