SAMD21 (QTPY) dependent on laptop connection for data
I'm using a samd21 (m0) qtpy microcontroller for my project. I connected an eink display to the qtpy. I read the data from an array in the Texts.h file. This worked fine on the arduino pro mini, but it has limit memory, that's why I switched to this mcu. Now i'm using the same code and it works all perfectly fine until I close my arduino ide or connect the controller to an external supply. So somehow it is depending on the pc for data... I am sure that the array is uploaded since the sketch size shrinks when I remove some of the lines in the aray.
The main sketch:
#include "Adafruit_ThinkInk.h"
#include "ArduinoLowPower.h"
#include "Texts.h"
#define EPD_CS      6
#define EPD_DC      7
#define SRAM_CS     3
#define EPD_RESET   5 // can set to -1 and share with microcontroller Reset!
#define EPD_BUSY    -1 // can set to -1 to not use a pin (will wait a fixed delay)
/* Pinout e-ink to seeed XIAO:
    SRCS = 3
    BUSY = 4
    RST = 5
    ECS = 6
    DC = 7
    MOSI = 11
    MISO = 12
    SCK = 13
int Randomtext = 0;
int Textentries = sizeof(Texts) / sizeof(Texts[0]);
// 2.13" Monochrome displays with 250x122 pixels and SSD1680 chipset
ThinkInk_213_Mono_BN display(EPD_DC, EPD_RESET, EPD_CS, SRAM_CS, EPD_BUSY);
  while (!Serial) {
    delay(10);
  display.begin(THINKINK_MONO);
  pinMode(EPD_RESET, OUTPUT);
  digitalWrite(EPD_RESET, HIGH);
  display.clearBuffer();
  display.setTextSize(2);
  testdrawtext(Texts[Randomtext = random(0, sizeof(Texts) / sizeof(Texts[0]))], EPD_BLACK); // pick a random text somewhere between 0 and the size of the Texts array
  Serial.print(Randomtext);
  Serial.print(F("Printing text: "));
  Serial.println(Texts[Randomtext]);
  display.display();
  LowPower.sleep(8000);
void testdrawtext(const char *text, uint16_t color) {
  display.setCursor(0, 0);
  display.setTextColor(color);
  display.setTextWrap(true);
  display.print(text);
small part of the .h file:
const char *Texts[] =
  // Compliments/personal development
    "You look beautifull today!",
    "Today is the day",
    "Nobody is perfect, but you're so close it's scary",
    "Your voice is my favorite sound",
Any idea why the mcu is dependent on the ide's data?
I found the problem:
  while (!Serial) {
    delay(10);
Of course it will not work, It waits on a connection with serial aka my computer.
