SAMD21 + u-blox + Sparkfun GPS lib
Does anyone know whether the Sparfun GPS library even works like that on SAMD21? I can't get this minimal program to work. No GPS time is displayed. If I use a Tinygps ++ it works fine on SAMD.
#include "SparkFun_u-blox_GNSS_Arduino_Library.h"
#include "wiring_private.h"
#define SerialCon Serial1
#define SerialGPS Serial2
SFE_UBLOX_GNSS myGNSS;
long lastTime = 0;
Uart SerialGPS(&sercom2, 3, 4, SERCOM_RX_PAD_1, UART_TX_PAD_0);
void SERCOM2_Handler()
  SerialGPS.IrqHandler();
  SerialCon.begin(115200);
  while (!SerialCon);
  SerialCon.println();
  SerialCon.println("Start..");
  SerialGPS.begin(9600);
  pinPeripheral(3, PIO_SERCOM_ALT);
  pinPeripheral(4, PIO_SERCOM_ALT);
  SerialCon.print("GPS u-blox init.. ");
  if (myGNSS.begin(SerialGPS))
    SerialCon.println("OK!");
    SerialCon.println("FAIL!");
  SerialCon.print("GPS u-blox set PVT.. ");
  if (myGNSS.setAutoPVT(true))
  myGNSS.setUART1Output(COM_TYPE_UBX); //Set the UART port to output UBX only
  //myGNSS.setI2COutput(COM_TYPE_UBX); //Set the I2C port to output UBX only (turn off NMEA noise)
  myGNSS.saveConfiguration(); //Save the current settings to flash and BBR
  if (millis() - lastTime > 1000)
    lastTime = millis(); //Update the timer
    if (myGNSS.getDateValid())
      SerialCon.print(myGNSS.getYear());
      SerialCon.print("-");
      SerialCon.print(myGNSS.getMonth());
      SerialCon.print(myGNSS.getDay());
      SerialCon.print(" ");
    if (myGNSS.getTimeValid())
      SerialCon.print(myGNSS.getHour());
      SerialCon.print(":");
      SerialCon.print(myGNSS.getMinute());
      SerialCon.print(myGNSS.getSecond());
