Same case scenario other outcomes SOLVED!
Hi everyone. This is my first post here, most of all because i always wants to find out the answer myself trough google or this forum, but i cant seem to find what i am looking for here.
I am working on a home automation project, like many others. I use the Easy VR shield for voice recoqnition and a simple 433 Mhz radio transmitter. Everything works great so far. I can easely turn on and off my power sockets in my home.
I want to take it a step up. Right now i am using a speek command like this:
Toggleword -> turnonlights // to turn on a plug
Toggleword -> turnofflights // to turn off a plug
All this is working with my switch case.
I would like to only say:
Toggleword -> Light // to turn on and when it is said the second time turn it off again.
Is there a way where i can get the arduino to remember if it is turned on and off, and then do the opposit when i say my voice command, maybe even in the same switch cases that i already have. Hope this makes sense to you guys.
Here is my code:
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #include "SoftwareSerial.h"
  SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
  #include "WProgram.h"
  #include "NewSoftSerial.h"
  NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
#include "RCSwitch.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_0  = 0,
  GROUP_1  = 1,
enum Group0
  G0_ARDUINO = 0,
enum Group1
  G1_TOEJTEAND = 0,
  G1_TOEJSLUK = 1,
  G1_LEDON = 2,
  G1_LEDOFF = 3,
  G1_LUFTUD = 4,
  G1_STOPLUFT = 5,
EasyVRBridge bridge;
int8_t group, idx;
RCSwitch mySwitch = RCSwitch();
  mySwitch.enableTransmit(10);
  // bridge mode?
  if (bridge.check())
    cli();
    bridge.loop(0, 1, 12, 13);
  // run normally
  port.begin(9600);
  if (!easyvr.detect())
    Serial.println("EasyVR not detected!");
    for (;;);
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(3);
  group = EasyVR::TRIGGER; //<-- start group (customize)
  pinMode(11, OUTPUT);
  digitalWrite(11, LOW);    // set the LED off
void action();
  easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
  easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again..." );
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
    group = GROUP_0;
void action()
    switch (group)
    case GROUP_0:
      switch (idx)
      case G0_ARDUINO:
        // write your action code here
          group = GROUP_1; //<-- or jump to another group X for composite commands
    case GROUP_1:
      switch (idx)
      case G1_LEDON:
        group = GROUP_0;
        mySwitch.switchOn("11001", "01000");   // Turns on light 1
      case G1_LEDOFF:
        group = GROUP_0;
        mySwitch.switchOff("11001", "01000"); // Turns off light 1
      case G1_TOEJTEAND:
        group = GROUP_0;
        mySwitch.switchOn("11101", "10000");   // Turns on light 2
      case G1_TOEJSLUK:
        group = GROUP_0;
        mySwitch.switchOff("11101", "10000"); // Turns off light 2
       case G1_LUFTUD:
        group = GROUP_0;
        mySwitch.switchOn("11101", "01000");   // Turns on light 3
      case G1_STOPLUFT:
        group = GROUP_0;
        mySwitch.switchOff("11101", "01000"); // Turns off light 3
Thanks in advance!
Of course.
bool lightsAreOn = true; // Lights start out on...
if(lightsAreOn)
   // turn them off
   lightsAreOn = false;
   // turn them on
   lightsAreOn = true;
Depending on what turning the lights on or off involves, you might even be able to simplify that:
   lightsAreOn = !lightsAreOn;
   digitalWrite(lightPin, lightsAreOn);
Thank you very much, that was exactly what i was looking for. I probrably made it a much bigger problem than it actually was. Thanks again!
