Same code the OLED shown different, why?
The two sketches have same display testing code, but shown different:
  This is an example for our Monochrome OLEDs based on SSD1306 drivers
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/category/63_98
  This example is for a 128x32 pixel display using I2C to communicate
  3 pins are required to interface (two I2C and one reset).
  Adafruit invests time and resources providing this open
  source code, please support Adafruit and open-source
  hardware by purchasing products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries,
  with contributions from the open source community.
  BSD license, check license.txt for more information
  All text above, and the splash screen below must be
  included in any redistribution.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO:       A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO:   2(SDA),  3(SCL), ...
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES     10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT   16
#define LOGO_WIDTH    16
static const unsigned char PROGMEM logo_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;); // Don't proceed, loop forever
  display.clearDisplay();
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0, 0); //Defining position to write from first row, first column .
  display.print("W B G Y R  AAA"); //// display.print("W B G Y R  CLK");
  display.setCursor(0, 10); //second line, 1st block
  display.print("0 0 0 0 0   0"); //You can write 16 Characters per line .
  display.setCursor(0, 20);
  display.println(F("Hello, world!"));
  display.display();
  delay(10000); //wait 3 sec
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  display.display();
  delay(2000); // Pause for 2 seconds
  // Clear the buffer
  // Draw a single pixel in white
  display.drawPixel(10, 10, SSD1306_WHITE);
  // Show the display buffer on the screen. You MUST call display() after
  // drawing commands to make them visible on screen!
  display.display();
  delay(2000);
  // display.display() is NOT necessary after every single drawing command,
  // unless that's what you want...rather, you can batch up a bunch of
  // drawing operations and then update the screen all at once by calling
  // display.display(). These examples demonstrate both approaches...
  testdrawline();      // Draw many lines
  testdrawrect();      // Draw rectangles (outlines)
  testfillrect();      // Draw rectangles (filled)
  testdrawcircle();    // Draw circles (outlines)
  testfillcircle();    // Draw circles (filled)
  testdrawroundrect(); // Draw rounded rectangles (outlines)
  testfillroundrect(); // Draw rounded rectangles (filled)
  testdrawtriangle();  // Draw triangles (outlines)
  testfilltriangle();  // Draw triangles (filled)
  testdrawchar();      // Draw characters of the default font
  testdrawstyles();    // Draw 'stylized' characters
  testscrolltext();    // Draw scrolling text
  testdrawbitmap();    // Draw a small bitmap image
  // Invert and restore display, pausing in-between
  display.invertDisplay(true);
  display.invertDisplay(false);
  testanimate(logo_bmp, LOGO_WIDTH, LOGO_HEIGHT); // Animate bitmaps
void testdrawline() {
  int16_t i;
  display.clearDisplay(); // Clear display buffer
  for (i = 0; i < display.width(); i += 4) {
    display.drawLine(0, 0, i, display.height() - 1, SSD1306_WHITE);
    display.display(); // Update screen with each newly-drawn line
    delay(1);
  for (i = 0; i < display.height(); i += 4) {
    display.drawLine(0, 0, display.width() - 1, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(0, display.height() - 1, i, 0, SSD1306_WHITE);
    display.display();
    delay(1);
  for (i = display.height() - 1; i >= 0; i -= 4) {
    display.drawLine(0, display.height() - 1, display.width() - 1, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(250);
  for (i = display.width() - 1; i >= 0; i -= 4) {
    display.drawLine(display.width() - 1, display.height() - 1, i, 0, SSD1306_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width() - 1, display.height() - 1, 0, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(display.width() - 1, 0, 0, i, SSD1306_WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width() - 1, 0, i, display.height() - 1, SSD1306_WHITE);
    display.display();
    delay(1);
void testdrawrect(void) {
  for (int16_t i = 0; i < display.height() / 2; i += 2) {
    display.drawRect(i, i, display.width() - 2 * i, display.height() - 2 * i, SSD1306_WHITE);
    display.display(); // Update screen with each newly-drawn rectangle
    delay(1);
  delay(2000);
void testfillrect(void) {
  for (int16_t i = 0; i < display.height() / 2; i += 3) {
    // The INVERSE color is used so rectangles alternate white/black
    display.fillRect(i, i, display.width() - i * 2, display.height() - i * 2, SSD1306_INVERSE);
    delay(1);
  delay(2000);
void testdrawcircle(void) {
  for (int16_t i = 0; i < max(display.width(), display.height()) / 2; i += 2) {
    display.drawCircle(display.width() / 2, display.height() / 2, i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfillcircle(void) {
  for (int16_t i = max(display.width(), display.height()) / 2; i > 0; i -= 3) {
    // The INVERSE color is used so circles alternate white/black
    display.fillCircle(display.width() / 2, display.height() / 2, i, SSD1306_INVERSE);
    display.display(); // Update screen with each newly-drawn circle
    delay(1);
  delay(2000);
void testdrawroundrect(void) {
  for (int16_t i = 0; i < display.height() / 2 - 2; i += 2) {
    display.drawRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i,
                          display.height() / 4, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfillroundrect(void) {
    // The INVERSE color is used so round-rects alternate white/black
    display.fillRoundRect(i, i, display.width() - 2 * i, display.height() - 2 * i,
                          display.height() / 4, SSD1306_INVERSE);
    display.display();
    delay(1);
  delay(2000);
void testdrawtriangle(void) {
  for (int16_t i = 0; i < max(display.width(), display.height()) / 2; i += 5) {
    display.drawTriangle(
      display.width() / 2  , display.height() / 2 - i,
      display.width() / 2 - i, display.height() / 2 + i,
      display.width() / 2 + i, display.height() / 2 + i, SSD1306_WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfilltriangle(void) {
  for (int16_t i = max(display.width(), display.height()) / 2; i > 0; i -= 5) {
    // The INVERSE color is used so triangles alternate white/black
    display.fillTriangle(
      display.width() / 2 + i, display.height() / 2 + i, SSD1306_INVERSE);
    display.display();
    delay(1);
  delay(2000);
void testdrawchar(void) {
  display.setTextSize(1);      // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE); // Draw white text
  display.setCursor(0, 0);     // Start at top-left corner
  display.cp437(true);         // Use full 256 char 'Code Page 437' font
  // Not all the characters will fit on the display. This is normal.
  // Library will draw what it can and the rest will be clipped.
  for (int16_t i = 0; i < 256; i++) {
    if (i == '\n') display.write(' ');
    else          display.write(i);
  display.display();
  delay(2000);
void testdrawstyles(void) {
  display.setTextColor(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
  display.println(3.141592);
  display.setTextSize(2);             // Draw 2X-scale text
  display.print(F("0x")); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
void testscrolltext(void) {
  display.setCursor(10, 0);
  display.println(F("scroll"));
  display.display();      // Show initial text
  delay(100);
  // Scroll in various directions, pausing in-between:
  display.startscrollright(0x00, 0x0F);
  delay(2000);
  display.stopscroll();
  display.startscrollleft(0x00, 0x0F);
  delay(2000);
  display.startscrolldiagright(0x00, 0x07);
  delay(2000);
  display.startscrolldiagleft(0x00, 0x07);
  delay(2000);
void testdrawbitmap(void) {
  display.drawBitmap(
    (display.width()  - LOGO_WIDTH ) / 2,
    (display.height() - LOGO_HEIGHT) / 2,
    logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
  display.display();
#define XPOS   0 // Indexes into the 'icons' array in function below
#define YPOS   1
#define DELTAY 2
void testanimate(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  int8_t f, icons[NUMFLAKES][3];
  // Initialize 'snowflake' positions
  for (f = 0; f < NUMFLAKES; f++) {
    icons[f][XPOS]   = random(1 - LOGO_WIDTH, display.width());
    icons[f][YPOS]   = -LOGO_HEIGHT;
    icons[f][DELTAY] = random(1, 6);
    Serial.print(F("x: "));
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(F(" y: "));
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(F(" dy: "));
    Serial.println(icons[f][DELTAY], DEC);
  for (;;) { // Loop forever...
    display.clearDisplay(); // Clear the display buffer
    // Draw each snowflake:
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, SSD1306_WHITE);
    display.display(); // Show the display buffer on the screen
    delay(200);        // Pause for 1/10 second
    // Then update coordinates of each flake...
      icons[f][YPOS] += icons[f][DELTAY];
      // If snowflake is off the bottom of the screen...
      if (icons[f][YPOS] >= display.height()) {
        // Reinitialize to a random position, just off the top
/* https://curiousscientist.tech/blog/arduino-menu-navigation-rotary-encoder
//16x2 LCD
///// #include <LiquidCrystal_I2C.h> //SDA = A4, SCL = A5
///// LiquidCrystal_I2C lcd(0x27, 16, 2);
#include <SPI.h>
#include <Wire.h>
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
//Defining pins for rotary encoder
const int RotaryCLK = 2; //CLK pin on the rotary encoder
const int RotaryDT = 4; //DT pin on the rotary encoder
const int RotarySW = 3; //SW pin on the rotary encoder (Button function)
//Defining variables for rotary encoder and button
int ButtonCounter = 0; //counts the button clicks
int RotateCounter = 0; //counts the rotation clicks
bool rotated = true; //info of the rotation
bool ButtonPressed = false; //info of the button
//Statuses
int CLKNow;
int CLKPrevious;
int DTNow;
int DTPrevious;
// Timers
float TimeNow1;
float TimeNow2;
//LED things
//digital pins
const int whiteLED = 8;
const int blueLED = 9;
const int greenLED = 10;
const int yellowLED = 11;
const int redLED = 12;
//statuses (1/true: ON, 0/false: OFF)
bool whiteLEDStatus = false;
bool blueLEDStatus = false;
bool greenLEDStatus = false;
bool yellowLEDStatus = false;
bool redLEDStatus = false;
//Drawing of the LCD layout
//W  B  G  Y  R   CLK
//0  0  0  0  0    1
  display.display();
  //setting up pins
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(whiteLED, OUTPUT); //white LED
  pinMode(blueLED, OUTPUT); //blue LED
  pinMode(greenLED, OUTPUT); //green LED
  pinMode(yellowLED, OUTPUT); //yellow LED
  pinMode(redLED, OUTPUT); //red LED
  //LOW pins = LEDs are off. (LED + is connected to the digital pin)
  digitalWrite(whiteLED, LOW);
  digitalWrite(blueLED, LOW);
  digitalWrite(greenLED, LOW);
  digitalWrite(yellowLED, LOW);
  digitalWrite(redLED, LOW);
  //Store states
  CLKPrevious = digitalRead(RotaryCLK);
  DTPrevious = digitalRead(RotaryDT);
  attachInterrupt(digitalPinToInterrupt(RotaryCLK), rotate, CHANGE);
  attachInterrupt(digitalPinToInterrupt(RotarySW), buttonPressed, FALLING); //either falling or rising but never "change".
  TimeNow1 = millis(); //Start timer 1
  printLCD();
  ButtonChecker();
void buttonPressed()
  //This timer is a "software debounce". It is not the most effective solution, but it works
  TimeNow2 = millis();
  if (TimeNow2 - TimeNow1 > 500)
    ButtonPressed = true;
  TimeNow1 = millis();  //"reset" timer; the next 500 ms is counted from this moment
void rotate()
  CLKNow = digitalRead(RotaryCLK); //Read the state of the CLK pin
  // If last and current state of CLK are different, then a pulse occurred
  if (CLKNow != CLKPrevious  && CLKNow == 1)
    // If the DT state is different than the CLK state then
    // the encoder is rotating CCW so increase
    if (digitalRead(RotaryDT) != CLKNow)
      RotateCounter++;
      if (RotateCounter > 4)
        RotateCounter = 0;
      RotateCounter--;
      if (RotateCounter < 0)
        RotateCounter = 4;
  CLKPrevious = CLKNow;  // Store last CLK state
  rotated = true;
void printLCD()
  if (rotated == true) //refresh the CLK
    /////  lcd.setCursor(12, 1);
    /////  lcd.print(RotateCounter);
    display.setCursor(12, 1);
    display.println(RotateCounter);
    rotated = false;
void ButtonChecker() //this is basically the menu part. keep track of the buttonpressed and rotatecounter for navigation
  if (ButtonPressed == true)
    switch (RotateCounter)
      case 0:
        if (whiteLEDStatus == false)
          whiteLEDStatus = true;
          digitalWrite(whiteLED, HIGH); //white LED is turned ON
          digitalWrite(whiteLED, LOW); //white LED is turned OFF
        /////  lcd.setCursor(0,1); // Defining positon to write from second row, first column .
        display.println(whiteLEDStatus);
        ///// lcd.print(whiteLEDStatus);
      case 1:
        if (blueLEDStatus == false)
          blueLEDStatus = true;
          digitalWrite(blueLED, HIGH);
        /////  lcd.setCursor(2,1); // Defining positon to write from second row, first column .
        ///// lcd.print(blueLEDStatus);
        display.setCursor(2, 1);
        display.println(blueLEDStatus);
      case 2:
        if (greenLEDStatus == false)
          greenLEDStatus = true;
          digitalWrite(greenLED, HIGH);
        /////   lcd.setCursor(4, 1); // Defining positon to write from second row, first column .
        //////   lcd.print(greenLEDStatus);
        display.setCursor(4, 1);
      case 3:
        if (yellowLEDStatus == false)
          yellowLEDStatus = true;
          digitalWrite(yellowLED, HIGH);
        /////   lcd.setCursor(6, 1); // Defining positon to write from second row, first column .
        /////   lcd.print(yellowLEDStatus);
        display.setCursor(6, 1);
        display.println(yellowLEDStatus);
      case 4:
        if (redLEDStatus == false)
          redLEDStatus = true;
          digitalWrite(redLED, HIGH);
        //////  lcd.setCursor(8, 1); // Defining positon to write from second row, first column .
        ////// lcd.print(redLEDStatus);
        display.setCursor(8, 1);
        display.println(redLEDStatus);
  ButtonPressed = false; //reset this variable
  display.display();
  delay(2000);
why are the heights different?
Thank you.
DONE!
