When I run this Adafruit Sensor Lab example:
#include "Adafruit_Sensor_Calibration.h"
// select either EEPROM or SPI FLASH storage:
#ifdef ADAFRUIT_SENSOR_CALIBRATION_USE_EEPROM
Adafruit_Sensor_Calibration_EEPROM cal;
#else
Adafruit_Sensor_Calibration_SDFat cal;
#endif
while (!Serial) delay(10);
delay(100);
Serial.println("Calibration filesys test");
if (!cal.begin()) {
Serial.println("Failed to initialize calibration helper");
while (1) yield();
Serial.print("Has EEPROM: "); Serial.println(cal.hasEEPROM());
Serial.print("Has FLASH: "); Serial.println(cal.hasFLASH());
if (! cal.loadCalibration()) {
Serial.println("No calibration loaded/found... will start with defaults");
Serial.println("Loaded existing calibration");
// in uTesla
cal.mag_hardiron[0] = -3.35;
cal.mag_hardiron[1] = -0.74;
cal.mag_hardiron[2] = -40.79;
// in uTesla
cal.mag_softiron[0] = 0.965;
cal.mag_softiron[1] = 0.018;
cal.mag_softiron[2] = 0.010;
cal.mag_softiron[3] = 0.018;
cal.mag_softiron[4] = 0.960;
cal.mag_softiron[5] = 0.003;
cal.mag_softiron[6] = 0.010;
cal.mag_softiron[7] = 0.003;
cal.mag_softiron[8] = 1.080;
// Earth total magnetic field strength in uTesla (dependent on location and time of the year),
// visit: https://www.ngdc.noaa.gov/geomag/calculators/magcalc.shtml#igrfwmm)
cal.mag_field = 45.00; // approximate value for locations along the equator
// in Radians/s
cal.gyro_zerorate[0] = 0.05;
cal.gyro_zerorate[1] = -0.01;
cal.gyro_zerorate[2] = -0.01;
if (! cal.saveCalibration()) {
Serial.println("**WARNING** Couldn't save calibration");
Serial.println("Wrote calibration");
cal.printSavedCalibration();
I am getting this:
I think this is a separate issue, but could also be related since I am doing the calibration in this way with the Mega. It looks like that code is not finding the Flash memory of the 33 IoT.
