I'm using an Arduino Uno with Funduino I2C 1602 LCD display. The LCD display is connected as
LCD
SCL--> A5 SDA -->A4
I need to measure the temperature, pressure and the velocity of a duct flow. So I connected a BMP180 sensor to my arduino with the following connection
SCL--> A5 SDA -->A4
As you can see, both of them are connected to same pins. The connection works fine just for BMP180 but when I add a rotary encoder and print its value on LCD, I'm getting delayed and wrong data.
I'm using this BMP180 library GitHub - adafruit/Adafruit_BMP085_Unified: Unified sensor driver for Adafruit's BMP085 & BMP180 breakouts
The LCD uses this library (v1.2.0)
https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
how can I change bmp180 or LCD analog pins in these libraries?
