I am working with the OPTA and its extenders for an automation project. The same action in the loop behaves differently depending on whether I upload the code using the Arduino IDE or the Arduino Cloud. When executed through the Arduino Cloud, it seems that the loop resets after completing the first delay in the function. However, the same function executes correctly without any issues when uploaded through the Arduino IDE.
void controlCirculation() {
controlGVA(0,true);
controlGVA(1,false);
controlGVA(2,false);
controlGVA(3,false);
delay(60000);
controlGVA(1,true);
delay(3000);
controlGVA(0,false);
delay(60000);
controlGVA(2,true);
delay(3000);
delay(60000);
controlGVA(3,true);
delay(3000);
delay(60000);
controlGVA(4,true);
delay(3000);
delay(60000);
controlGVA(5,true);
delay(3000);
controlGVA(4,false);
delay(60000);
controlGVA(0,true);
controlGVA(1,true);
controlGVA(2,true);
controlGVA(3,true);
controlGVA(5,false);
ArduinoCloud.update();
OptaController.update();
String currentTimeStr1 = getLocalTime();
int currentHour = hour();
int currentMinute = minute();
int currentSecond = second();
Serial.println(currentTimeStr1);
if (readButtonState(0)) { // Main loop state
Serial.println("Main loop state");
// Perform sensor readings and updates
readRTDs();
float pressures[3];
String logString;
readPressures(pressures, logString);
String mfm = getMFMReading();
String irradiance = readPyranometer();
// Update the "values" string
values = "Panel Temp: " + String(panelTemp, 2) + "C, " +
"Ambient Temp: " + String(ambientTemp, 2) + "C, " +
mfm + irradiance +
"Panel Pressure: " + String(pressures[0], 2) + ", " +
"Pump Pressure: " + String(pressures[2], 2);
Serial.println("Updated values: " + values);
// Perform other main loop actions
if (!isPulsing) {
setPumpVoltage(3000);
// Handle time-based actions
if (hour() >= 6 && hour() < 17) {
handlePumpPulse();
controlTECWithPID();
controlDrainValve("timed");
if (gvb2_open) {
controlGVB(2, false); // Close GVB 2
gvb2_open = false;
if (!gvb2_open) {
controlGVB(2, true); // Open GVB 2
gvb2_open = true;
delay(3000);
return; // Exit loop after handling Button 0
// Button 1: Perform KOH and HS Filling
if (readButtonState(1)) {
// Perform KOH filling
SF1kohfilling();
Serial.println("Button 0 pressed. Returning to main loop.");
return;
// If Button 0 is not pressed, proceed to HS filling
String hsFillingResult = SF2_HS_filling();
Serial.println("HS Filling Result: " + hsFillingResult);
// Button 3: SF3 State
if (readButtonState(3)) {
Serial.println("SF3 state");
SF3_PC_LOAD();
delay(3000);
if (readButtonState(2) ) {
controlCirculation();
// Handle idle state
if (!readButtonState(0) && !readButtonState(1) && !readButtonState(2) && !readButtonState(3) &&
readLevelSensor(0) && readLevelSensor(1)) {
// Button 2: SF4 State
if (!gvb2_open) {
gvb2_open = true; // Mark GVB as open
controlDrainValve("manual", "on");
// Recheck for button presses periodically
while (!readButtonState(0) && !readButtonState(1) && !readButtonState(2) && !readButtonState(3)) {
delay(100); // Non-blocking delay
Serial.println("Button pressed during idle. Returning to main loop.");
return;
// Ensure GVB is properly closed if not needed
if (currentHour < 6 || currentHour >= 17) {
if (gvb2_open) {
controlGVB(2, false); // Close GVB 2 outside the active hours
gvb2_open = false; // Update flag
