same ol problem ? was working a week ago now its not ?
hello I was on here about a week ago with a problem ..I had an interrupt not firing well cattledog helped me figure it out ..well I left this project alone for a little while well i decided to revisit the project
and now it is doing the same thing one of my interrupts won't fire and Im sure everything is the same
well here is the code please tell me if you see any mistakes cuz i don't think anything is different
#include <Wire.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <util/delay.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads(0x48);
int16_t adc0;  // we read from the ADC, we have a sixteen bit integer as a result
LiquidCrystal_I2C lcd(0x3f, 20,4);
int flag = 0;
int sensorValue=0;
float voltage=0,v1=0,v2=0;
  DDRD = 0b00000000;
  lcd.begin(16,2);  // initialize the lcd added and works
  lcd.init();       // initialize the lcd
  lcd.init();
  lcd.backlight();
 EIMSK =0x3; // Turns on INT0 and INT1
  //****************************INT1**********************************************************INT1
 PORTD|= (1 << PORTD3);   // turn On the Pull-up PD3 is now an input with pull-up enabled
 EICRA = (1 << ISC11) | (1 << ISC10); // set INT1 to trigger on rising edge
 //****************************INT0**********************************************************INT0
 PORTD|= (1 << PORTD2);   // turn On the Pull-up PD3 is now an input with pull-up enabled
 EICRA = (1 << ISC01) | (0 << ISC00); // set INT0 to trigger on falling edge
  if (flag == 1)
    adc0 = ads.readADC_SingleEnded(0);
    voltage = (adc0 * 0.1875)/1000;
    lcd.setCursor(0,0);
    lcd.print("A0=");
    lcd.print(voltage,5);
    lcd.setCursor(8,0);
    lcd.print(" Falling         ");
    delay(100);
    flag = 0;
  if (flag == 2)
    lcd.setCursor(0,1);
    lcd.print("A0=");
    lcd.setCursor(8,1);
    float hyst;
    if(v1>v2){v1-v2; lcd.setCursor(0,3); lcd.print("Hyst=");lcd.print(v1);}
    if(v1<v2){v2-v1; lcd.setCursor(0,3); lcd.print("Hyst=");lcd.print(v2);}
    lcd.print(" Rising         ");
     delay(100);
    flag = 0;
  sei(); // turn on interrupts
}//END OF LOOP
//*************INT1************
ISR (INT1_vect)
flag = 1;
//*****END-OF-ISR**************
//*************INT0************
ISR (INT0_vect)
flag = 2;
bandmwhitt2013:
Kepner & Tregoe told us decades ago that if something is working different, then something must have changed.
well yea mmmmmm Not sure what ? well .....Ill just keep working on it
Code does not change by itself. However, hardware if incorrectly made can. It looks like you have something wrong with your connections. This has all the hall marks of something being made on solderless bread board which is notorious for intermittent connections, especially the cheap stuff.
So instead of showing us the code, then show us the schematic and a clear photograph showing the wiring.
thanks mike ill look in to that
Same problem as last time. The second setting of EICRA is overwriting the first because of the = instead of the |=
Go back and review your last post in the previous thread.
ahhh lol thanks again cattledog
from this day on i will not forget the | Im stupid at times
