I have some diagnostic LEDs set up to check if certain states are triggering while I test my code. I've set two of them up to blink if the a state is true. I used the same code running the same blink rate on both but one is blinking at 500ms and one is blinking at 5000ms. Any idea what is causing this?
Relevant code
//Status light blink
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long blinkPeriod = 600;
pinMode(ledPinStatus, OUTPUT);
pinMode(ledPinStatus2, OUTPUT); //debug pin
//Status light
if (Reset == true && Edit == false)
{ digitalWrite(ledPinStatus, LOW); }
if (Reset == false && Edit == false)
{ digitalWrite(ledPinStatus, HIGH); }
//Blink timer
currentMillis = millis(); //get the current "time" (actually the number of milliseconds since the program started)
if (currentMillis - startMillis >= blinkPeriod && Edit == true ) //test whether the period has elapsed
digitalWrite(ledPinStatus, !digitalRead(ledPinStatus));
startMillis = currentMillis;
//Utility
if (Edit == false)
{ digitalWrite(ledPinStatus2, LOW); }
if (Edit == true && EditDelay == false)
{ digitalWrite(ledPinStatus2, HIGH); }
if (currentMillis - startMillis >= blinkPeriod && Edit == true && EditDelay == true)
digitalWrite(ledPinStatus2, !digitalRead(ledPinStatus2));
Full code
int ledPinRed = 5;
int ledPinGreen = 6;
int ledPinStatus = 3;
int ledPinStatus2 = 9; //debug pin
int buttonNeg = 8;
int buttonPos = 7;
int buttonTrig = 10;
int buttonClr = 11;
int buttonEdit = 2;
// Control
int Reset = false;
int Edit = false;
int EditDelay = false;
int maxReadDelay = 10000;
int ReadDelay = maxReadDelay;
int maxBrightness = 255; //this can be any number - it's the number of steps between dimmest and brightest.
int brightness = maxBrightness;
int interval1=10; //LED brightness
int interval2=1000; //result delay
// Results
int Zombie = false;
int Human = false;
// Misc
pinMode(ledPinRed, OUTPUT);
pinMode(ledPinGreen, OUTPUT);
pinMode(buttonNeg, INPUT_PULLUP);
pinMode(buttonPos, INPUT_PULLUP);
pinMode(buttonTrig, INPUT_PULLUP);
pinMode(buttonClr, INPUT_PULLUP);
pinMode(buttonEdit, INPUT_PULLUP);
//POSITIVE
if (digitalRead(buttonPos) == LOW && Edit == false && Human == false)
{ Zombie = true;
Human = false; }
if (digitalRead(buttonTrig) == LOW && Zombie == true && Edit == false)
{ delay (ReadDelay);
analogWrite(ledPinRed, brightness); }
//NEGATIVE
if (digitalRead(buttonNeg) == LOW && Edit == false && Zombie == false)
{ Human = true;
Zombie = false; }
if (digitalRead(buttonTrig) == LOW && Human == true && Edit == false)
analogWrite(ledPinGreen, brightness); }
//RESET
if (digitalRead(buttonClr) == LOW && Reset == false && Edit == false)
Reset = true;
if (digitalRead(buttonClr) == LOW && Reset == true && Edit == false)
digitalWrite(ledPinRed, LOW);
digitalWrite(ledPinGreen, LOW);
Zombie = false;
Human = false;
Reset = false;
//EDIT MODE
//Mode switch
if (digitalRead(buttonEdit) == LOW && Edit == false)
{ delay(500);
Edit = true; }
if (digitalRead(buttonEdit) == LOW && Edit == true)
{ delay(500);
Edit = false;
EditDelay = false;
//Intensity
if (digitalRead(buttonNeg) == LOW && brightness < maxBrightness && Edit == true && EditDelay == false)
brightness += interval1;
delay(100);
analogWrite(ledPinRed, map(brightness, 0, maxBrightness, 0, 255));
analogWrite(ledPinGreen, map(brightness, 0, maxBrightness, 0, 255));
if (digitalRead(buttonPos) == LOW && brightness > 0 && Edit == true && EditDelay == false)
brightness -= interval1;
delay(100);
//Read Delay
if (digitalRead(buttonTrig) == LOW && Edit == true && EditDelay == false)
delay (500);
EditDelay = true;
if (digitalRead(buttonTrig) == LOW && Edit == true && EditDelay == true)
delay (500);
EditDelay = false;
if (digitalRead(buttonNeg) == LOW && ReadDelay < maxReadDelay && Edit == true && EditDelay == true)
ReadDelay += interval2;
if (digitalRead(buttonPos) == LOW && ReadDelay < maxReadDelay && Edit == true && EditDelay == true)
ReadDelay -= interval2;
//Status light
//Blink timer
//Utility
if (Edit == false)
