sample and encode a picture
I want to take a camera-say a cheap webcam- and do the following.. Take a still picture. Then pixelate it down to a low level of resolution. Form an array of rows and columns. Then encode each pixel in a column as follows; Top pxl of column, say 5 Khz audio, bottom pxl of column 500Hz audio. The brightness of the pxl is encoded as amplitude of the audio. Is this sampling and processing feasible with Arduino variants?
Is it feasible to hack into such a camera (because USB is offered)? Advice, please, will be listened to most carefully.
For reference, a 32 x 32 pixel image, with eight bits per pixel occupies 1 kbyte. Is that low enough resolution?
On a PC, this would be trivially simple. Simply reading an image is beyond the capability of most Arduinos but you might be able to do something if you choose one of the Arduinos with additional RAM, if you are prepared to accept very low image resolution and update frequencies. What sort of frequency and resolution are you aiming for? Will it be a colour image? Where do the audio frequency domain values come from?
Thanks for prompt responses. I am experimenting with The vOICe which is a well known sensory substitution system for blind users. The system is capable of great subtlety of interpretation.. I wish to take it on at the minimum level of resolution and simplification, to see how much functionality might remain at the lower ends. I would hope to see it employed as a wearable collision avoidance/reaching/aiming device adjunct to the familiar white stick. I am aware that Raspberry-pi developers are applying themselves ,via Android 4.0, to creating a truly wearable and low-cost ,full-performance version. This being so, I still need to find out how to sample a B/W camera output , pixelate it at reduced resolution, encode the audio, and read out the mixed audio chord as a left-to right scan of the picture columns. The whole process is repeated at one frame per second. I would appreciate some ballpark figures for the possible bandwidths, storage and speeds required for a device as described. Is it really beyond the power of one of the bigger `duinos? Thanks... (There is an excellent information website at seeingwithsound.com ,if you are interested.)
Yes. Unless you consider the new Due.
Have a read of this:- www.robozes.com/inaki/dproject/report.pdf
