I thought some here might find this useful. I've written code for both ESP32 and the Sparkfun Thing Plus (SAMD51/Cortex M4) for sound generation that includes control over not only pitch, but also volume and wave form (duty cycle). Usually this is done with a DAC and a sine wave table, but my approach uses two timers and interrupts. I've tested this approach on the M4 vs a DAC, and my approach not only leaves the DAC free, but uses less processor time too. The code involves snippets from others I've seen on this form, so I also wanted to give back. Anyway, if you're looking for a light weight way to generate sound with volume and wave form control, without a DAC, hopefully this sample code helps, or gives some inspiration.
Here's a video demo of the code working on a Thing Plus: Michael Barkasi on Instagram: "I’ve been working more on my bare-metal digital sound synthesis. There’s no DAC, no wave tables, just a single digital pin and a bunch of timers. I can control pitch, volume, wave width, and harmonic overtone levels. #arduino #arduinoproject #arduinosound #digitalsound #digitalsoundsynthesis #soundsynthesis #baremetalprogramming"
The basics:
* The code for the base (240kHz) wave form (from TCC1) is taken largely from a post by MartinL (Jan 2019) on the Arduino forums;
* See: https://forum.arduino.cc/t/metro-m4-express-atsamd51-pwm-frequency-and-resolution/566491/2
* It was originally written written for the Metro M4, to run at some other frequency
* (I changed the timer speeds, prescalers, and PER/CC0 values to adjust frequency to 240kHz).
* I modified the code to work with the SparkFun Thing Plus (SAMD51) by looking up the necessary registery values in the SAMD51 datasheet (see page numbers below).
* It's written to work with pin D11 of the SparkFun Thing Plus, which is pin PA16 on the SAMD51; which (I believe) must be used with TCC1/WO[0]
* (This latter part is also a modification from MartinL, who used TCC0.)
* Finally, to get the base wave form to actually generate a signal on D11,
* I needed two more lines of code, to set DIRSET and OUTCLR, which I got from Shawn Hymel's write-up (Dec 22, 2018);
* See: https://shawnhymel.com/1710/arduino-zero-samd21-raw-pwm-using-cmsis/
* Shawn notes that his write-up is also based on posts by MartinL.
* The code for the timer controlling the hearable oscilation (TC0) is adapted from:
* https://emalliab.wordpress.com/2021/04/16/comparing-timers-on-samd21-and-samd51-microcontrollers/
* I've changed it a bit, including switching from the slow 32 kHz oscilator for a fast clock, to give better pitch control/resolution.
/* How the sound is generated: Two timers are used. The first (TCC1) controls a base wave form of digital pulses with 240 kHz oscilation.
Since we're using a TCC and TC, we can do PWM (pulse-width modulation). 240 kHz is too fast for a speaker, which (acting as a low-pass filter)
only "sees" the average voltage, which is digital HIGH * duty cycle. (Duty cycle is pulse width, e.g. pulse on for 70% of the period and off
for 30%.) The second timer (TC0) oscilates pulse width (duty cycle) of this wave at a hearable frequency, flipping between 0 and some second
nonzero value. This second nonzero value essentially ends up controlling volume, since it covaries with the voltage "seen" on each pulse by the speaker.*/
volatile int VOL = 499; /* As just explained, this value controls volume.
It should range between 0 and 499.
499 is the TOP value of the counter controlling the base 240 kHz wave form;
duty cycle ends up being VOL / 499. */
volatile int TF = 440; /* Tone frequency; Mathematically, anything from 183 to 6 million are valid
given the code/math/architecture. Values below 183 will overflow the 16-bit register,
and values over 6 million end up in nonsense like dividing by zero or negative numbers.
Of course, since a good audible range is something like 200 to 2000, this is fine.
Why initialize at 440? It's sort of pleasing. */
volatile long TCTOPL = 12000000L / (2 * TF) - 1; /* Variable stores CC0 (TOP) value of counter TC0, which is the counter ultimately controlling the tone pitch.
Every time this timer overflows, pulse width of the base waveform is flipped between 0 and some nonzero value,
hence this counter must overflow twice for one period of the tone frequency. Frequency (pitch) of the tone is
thus equal to oscilator speed (cycles per sec) divided by the number of times the counter overflows twice. Since
the oscilator used for TC0 runs at 12 MHz, this means that TF = 12000000 / (2 * (TCTOP - 1)). We have to subtract 1
because the counter starts at 0, not 1. A simple rearrangement of this equation gets us the formula
for TCTOP.
Note: We need this extra step because 12000000 is longer than 16 bit;
a 32 kHz oscilator would save us this step, but would offer poor control/resolution of tone pitch. */
volatile int TCTOP = (uint16_t)TCTOPL; /* Finally, convert into int16 for register */
// Setup TCC1, which will generate the base pulse wave
// Set up the generic clock (GCLK7) to clock timer TCC1
GCLK->GENCTRL[7].reg = GCLK_GENCTRL_DIV(1) | // Divide the 120 MHz clock source by divisor 1: 120 MHz/1 = 120 MHz
GCLK_GENCTRL_IDC | // Set the duty cycle to 50/50 HIGH/LOW
GCLK_GENCTRL_GENEN | // Enable GCLK7
GCLK_GENCTRL_SRC_DPLL0; // Select 120MHz DPLL clock source
while (GCLK->SYNCBUSY.bit.GENCTRL7); // Wait for synchronization
GCLK->PCHCTRL[25].reg = GCLK_PCHCTRL_CHEN | // Enable the TCC1 peripheral channel, see p. 169; 25 = GCLK_TCC1
GCLK_PCHCTRL_GEN_GCLK7; // Connect generic clock 7 to TCC1
// below: Port (ulPort) is PORTA; pin (ulPin) is PORT_PA16 (= D11)
PORT->Group[g_APinDescription[11].ulPort].DIRSET.reg = g_APinDescription[11].ulPin; // Set pin as output
PORT->Group[g_APinDescription[11].ulPort].OUTCLR.reg = g_APinDescription[11].ulPin; // Set pin as low
// Enable the peripheral multiplexer on pin D11
PORT->Group[g_APinDescription[11].ulPort].PINCFG[g_APinDescription[11].ulPin].bit.PMUXEN = 1;
// Set the D11 (PORT_PA16) peripheral multiplexer to the correct peripheral (even port number)
PORT->Group[g_APinDescription[11].ulPort].PMUX[8].reg |= 0x5; // see p. 900, 923
TCC1->CTRLA.reg = TC_CTRLA_PRESCALER_DIV1 | // Set prescaler to 1, 120 MHz/1 = 120 MHz
TC_CTRLA_PRESCSYNC_PRESC; // Set the reset/reload to trigger on prescaler clock
TCC1->WAVE.reg = TC_WAVE_WAVEGEN_NPWM; // Set-up TCC1 timer for Normal (single slope) PWM mode (NPWM)
while (TCC1->SYNCBUSY.bit.WAVE) // Wait for synchronization
TCC1->PER.reg = 499; // Set-up the PER (period) register; this value is chosen to produce a pulse at 240 kHz (see formula below)
while (TCC1->SYNCBUSY.bit.PER); // Wait for synchronization
// Formula: f_PWM = f_GCLKTCC / (PRESCALER (PER + 1))
// In this case, f_GCLKTCC = 120 MHz, PRESCALER = 1; 120 x 10^6 / 500 = 240 x 10^3
TCC1->CC[0].reg = VOL; // Set-up the CC (counter compare), channel 0 register; Recall, this controls volume.
while (TCC1->SYNCBUSY.bit.CC0); // Wait for synchronization
TCC1->CTRLA.bit.ENABLE = 1; // Enable timer TCC1
while (TCC1->SYNCBUSY.bit.ENABLE); // Wait for synchronization
// Setup TC0, which will generate a hearable oscilation off the base pulse wave:
// Set up a generic clock (GCLK8) to clock timer TC0
GCLK->GENCTRL[8].reg = GCLK_GENCTRL_DIV(4) | // Divide the 48MHz clock source by divisor 4: 48MHz/1 = 12MHz
GCLK_GENCTRL_GENEN | // Enable GCLK8
GCLK_GENCTRL_SRC_DFLL; // Select 48MHz DFLL clock source
while (GCLK->SYNCBUSY.bit.GENCTRL8); // Wait for synchronization
GCLK->PCHCTRL[9].reg = GCLK_PCHCTRL_CHEN | // Enable the TC0 peripheral channel, see p. 169; 9 = GCLK_TC0
GCLK_PCHCTRL_GEN_GCLK8; // Connect generic clock 8 to TC0
TC0->COUNT16.CTRLA.bit.ENABLE = 0; // Disable TC0
while (TC0->COUNT16.SYNCBUSY.bit.ENABLE); // Wait for sync
TC0->COUNT16.CTRLA.reg = TC_CTRLA_SWRST; // Reset TC0
while (TC0->COUNT16.SYNCBUSY.bit.SWRST); // Wait for sync
TC0->COUNT16.CTRLA.reg = TC_CTRLA_MODE_COUNT16; // Set TC0 for 16 bit mode? (Isn't that default?)
TC0->COUNT16.WAVE.reg = TC_WAVE_WAVEGEN_MFRQ; // Set TC0 wave generation mode to Match Frequency Generation
TC0->COUNT16.CTRLA.reg = TC_CTRLA_PRESCALER_DIV1 | TC_CTRLA_ENABLE; // No prescaler (Divide by 1)
TC0->COUNT16.CC[0].reg = TCTOP; // Write the counter value controlling wave form frequency
while (TC0->COUNT16.SYNCBUSY.reg > 0); // Wait for sync
// Setup the interrupts used to adjust pulse width of the base 240 kHz wave form
NVIC_DisableIRQ(TC0_IRQn);
NVIC_ClearPendingIRQ(TC0_IRQn);
NVIC_SetPriority(TC0_IRQn, 0);
NVIC_EnableIRQ(TC0_IRQn);
// Set interrupt register
TC0->COUNT16.INTENSET.bit.MC0 = 1;
void loop() {}
// This handler is what actually uses the second timer (TC0) to generate the hearable oscilation off the pulse wave generated by the first timer (TCC1).
void TC0_Handler(void) {
// If this interrupt is due to the compare register matching the timer count
if (TC0->COUNT16.INTFLAG.bit.MC0 == 1) { // p. 64
TC0->COUNT16.INTFLAG.bit.MC0 = 1;
if ( TCC1->CC[0].reg == 0 ) {
else {
TCC1->CC[0].reg = 0;
With two TCC timers to allow control of duty cycle:
* The code for the timer controlling the hearable oscilation (TCC2) is inspired by a mixature of the above sources and from:
Since we're using two TCC timers, we can do PWM (pulse-width modulation). 240 kHz is too fast for a speaker, which (acting as a low-pass filter)
for 30%.) The second timer (TCC2) oscilates pulse width (duty cycle) of this wave at a hearable frequency, flipping between 0 and some second
Since we're using a TCC timer (not a TC), we have more control than just a "top" or overflow value; For a TC timer, we'd be limited to having the pulse width
of the base wave (from TCC1) flip on every overflow, e.g. flipping between 0 and some non-zero volume level. The duty cycle, though, of this hearable oscilation
must remain a fixed 50/50 with the TC method. By switching to a TCC timer, we can have the timer start/overflow initiate a non-zero value for the TCC1 duty cycle (volume),
then have the timer's top value initiate a zero value, allowing us to control the duty cycle of the hearable oscilation.
By running the second timer (TCC2) at twice the intended frequency, we can run separate volume levels for every other wave form, allowing for under tones.
For example, running at 880Hz, every other wave form could be a 80% duty cycle for TCC1, while the rest are at 30%, giving a main 440Hz sound with undertones at 880Hz.
If you don't want the undertones (harmonics) but want control of the sound's duty cycle, eliminate the harmonics variable and run all the TCC2 overflows the same.*/
volatile int VOL_harmonic = (int)( VOL * 0.15 );
for TCTOP.
volatile float pulsefraction = 0.6;
bool harmonic = true;
// Setup TCC2, which will generate a hearable oscilation off the base pulse wave:
// Set up a generic clock (GCLK8) to clock timer TCC2
GCLK->PCHCTRL[29].reg = GCLK_PCHCTRL_CHEN | // Enable the TCC2 peripheral channel, see p. 169; 9 = GCLK_TCC2
GCLK_PCHCTRL_GEN_GCLK8; // Connect generic clock 8 to TCC2
TCC2->CTRLA.bit.ENABLE = 0; // Disable TCC2
while (TCC2->SYNCBUSY.bit.ENABLE); // Wait for sync
TCC2->CTRLA.reg = TC_CTRLA_SWRST; // Reset TCC2
while (TCC2->SYNCBUSY.bit.SWRST); // Wait for sync
TCC2->WAVE.reg = TC_WAVE_WAVEGEN_NPWM; // Set TCC2 wave generation mode to Match Frequency Generation
TCC2->CTRLA.reg = TC_CTRLA_PRESCALER_DIV1 | TC_CTRLA_ENABLE; // No prescaler (Divide by 1)
TCC2->PER.reg = TCTOP;
TCC2->CC[0].reg = (int) TCTOP * pulsefraction; // Write the counter value controlling wave form frequency
while (TCC2->SYNCBUSY.reg > 0); // Wait for sync
// Basic idea: MC0 is triggered on a CC0 match, OVF when the counter hits top. See pp. 1766, 1976, 1984
NVIC_DisableIRQ(TCC2_1_IRQn); // TCC2_1_IRQn is 98, the number for the MC0 channel (see p. 73)
NVIC_ClearPendingIRQ(TCC2_1_IRQn);
NVIC_SetPriority(TCC2_1_IRQn, 0);
NVIC_EnableIRQ(TCC2_1_IRQn);
TCC2->INTENSET.bit.MC0 = 1;
NVIC_DisableIRQ(TCC2_0_IRQn); // TCC2_0_IRQn is 97, the number for the overflow (OVF) channel (see p. 73)
NVIC_ClearPendingIRQ(TCC2_0_IRQn);
NVIC_SetPriority(TCC2_0_IRQn, 0);
NVIC_EnableIRQ(TCC2_0_IRQn);
TCC2->INTENSET.bit.OVF = 1;
void loop() {}
// This handler is what actually uses the second timer (TCC2) to generate the hearable oscilation of the pulse wave generated by the first timer (TCC1).
void TCC2_0_Handler(void) {
if (TCC2->INTFLAG.bit.OVF == 1) //Test if an OVF-Interrupt has occured
TCC2->INTFLAG.bit.OVF = 1; //Clear the Interrupt-Flag
if (harmonic) {
TCC1->CC[0].reg = VOL_harmonic;
harmonic = !harmonic;
else {
void TCC2_1_Handler(void) {
if (TCC2->INTFLAG.bit.MC0 == 1) //Test if an MC0-Interrupt has occured
TCC2->INTFLAG.bit.MC0 = 1; //Clear the Interrupt-Flag
For ESP32:
Setup base wave form @ 152,380 Hz using the ESP32's hardware PWM
152,380 Hz is the fastest oscilation its hardware PWM can achieve with at least 9 bit of resolution
Get this with: clk_src = LEDC_APB_CLK (80 MHz).
... then duty resolution is integer (log 2 (LEDC_APB_CLK / frequency))
see:
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/ledc.html
https://github.com/espressif/esp-idf/blob/5893797bf068ba6f72105fff289ead370b4591a3/examples/peripherals/ledc/ledc_basic/main/ledc_basic_example_main.c
Initial code to get PWM working from: https://randomnerdtutorials.com/esp32-pwm-arduino-ide/
Note: We really want this PWM to run in LEDC_HIGH_SPEED_MODE; the code from the esp-idf gives this control, but not the code for arduino;
Currently; assuming arduino puts PWM into high-speed mode by default
#define DACwave // uncomment to use DAC to generate base pulse wave instead of ttPWM
const int update_rate = 1000; // Controls both sound updates and when to process sensor data/ update motion models
// Variables controlling base pulse wave production / volume control
#ifdef DACwave
const int soundPin = A1; // DAC is set to use DAC1, which is A1; DAC2 is A0
const int amp_max = 255; // DAC is 8-bit, so only 256 levels
#else
const int soundPin = 13;
const int base_wave_freq = 152380; // highest availabe with 9 bit resolution is 152380
const int pwm_Channel = 0;
const int pwm_resolution = (int) log2( 80000000 / base_wave_freq ) ;
const int amp_max = pow(2,pwm_resolution) - 1; // for 9 bit resolution: 2^9 - 1 = 511; for 8 bit 2^8 - 1 = 255
#endif
volatile int amp = (int) amp_max * 0.5;
// setting the timer for generating hearable oscilation
const int pitch_initial = 440;
volatile int pitch = pitch_initial;
hw_timer_t * timerSW = NULL;
portMUX_TYPE timerSWMux = portMUX_INITIALIZER_UNLOCKED;
const int timerSWprescaler = 2; // Timers are 80Mhz; counters seem to be at least 32bit, so, don't need to prescale down low
const long timerSize = 80000000;
const int timerSizeprescaler = timerSize/timerSWprescaler;
volatile int timerSW_top = (int) timerSizeprescaler / (pitch * 2); // controls frequency of hearable oscilation
volatile bool up = true;
void update_pitch ( int new_pitch ) {
timerSW_top = (int) timerSizeprescaler / (new_pitch * 2);
timerAlarmWrite(timerSW, timerSW_top, true); // true = reload automatically
// interrupt handlers for timers generating hearable oscilation:
void IRAM_ATTR onTimerSW() {
portENTER_CRITICAL_ISR(&timerSWMux);
#ifdef DACwave
if (up) {
dacWrite(DAC1, amp);
dacWrite(DAC1, 0);
#else
if (up) {
ledcWrite(pwm_Channel, amp);
ledcWrite(pwm_Channel, 0);
#endif
up = !up;
portEXIT_CRITICAL_ISR(&timerSWMux);
// Variables for the timer controlling sound updates / motion processing
hw_timer_t * timerSU = NULL;
portMUX_TYPE timerSUMux = portMUX_INITIALIZER_UNLOCKED;
const int timerSU_top = (int) timerSizeprescaler / update_rate;
volatile bool update_now = false;
// interrupt handler for timer generating sound updates / motion processing:
void IRAM_ATTR onTimerSU() {
update_now = true;
void setup(){
// Setup base pulse wav
#ifdef DACwave
// print notice that DAC is used; nothing else to run
#else
// print notice that ttPWM is beeing used
ledcSetup(pwm_Channel, base_wave_freq, pwm_resolution); // configure PWM functionalitites
ledcAttachPin(soundPin, pwm_Channel); // attach the channel to the pin generating the wave
#endif
// Setup timer used for hearable oscilation
timerSW = timerBegin(0, timerSWprescaler, true); // true indicates counter goes up
timerAttachInterrupt(timerSW, &onTimerSW, true); // true indicates edge interrupt (false for level)
timerAlarmWrite(timerSW, timerSW_top, true); // true for reload automatically
timerAlarmEnable(timerSW);
// Setup timer for sound updates/ motion processing
timerSU = timerBegin(1, timerSWprescaler, true); // true indicates counter goes up
timerAttachInterrupt(timerSU, &onTimerSU, true); // true indicates edge interrupt (false for level)
timerAlarmWrite(timerSU, timerSU_top, true); // true for reload automatically
timerAlarmEnable(timerSU);
rdui
amp = amp_max;
void loop(){
if (update_now) {
if ( pitch < 2000 ) pitch += 1;
else pitch = pitch_initial;
update_pitch(pitch);
if ( amp < 5 ) amp = amp_max;
else amp -= 1;
update_now = false;
