Hmmm, I was hoping it was the UTFT library.
Well you can create your own keypad with what you are give from the library.
This is not from the library you are using but you should be able to see how to make a keypad.
#include <Wire.h>
#include <ITDB02_Touch.h>
#include <ITDB02_Graph16.h>
#include <TFT_Extension_old.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
//myGLCD(RS,WR,CS,RST,ALE,mode);
ITDB02 myGLCD(A1,A2,A0,A3,A5,ITDB32S); //
ITDB02_Touch myTouch(13,10,11,12,A4);
TFT_Extension_old myTFT(&myGLCD, &myTouch, LANDSCAPE);
char * text[4][3] = {
{"1","2","3"},
{"4","5","6"},
{"7","8","9"},
{"*","0","#"}
char Pass[5];
char master[5] = "2651";
int Pcount=0;
int XC,YC;
int PassCounter=0;
byte orient = LANDSCAPE;
myGLCD.InitLCD(LANDSCAPE);
myGLCD.setFont(SmallFont);
myTouch.InitTouch(LANDSCAPE);
myTouch.setPrecision(PREC_LOW);
for(int line = 0; line <= 239; line++) // custom background color
myGLCD.setColor(0, 0, line);//text color White
myGLCD.drawLine(0, line, 319, line);
PassWord_makeButton();
PassWord_buttonText();
//RUN();
GetNum();
void RUN()
// while(1) // Not using the Loop() function,
// myTouch.read();
// int tx = myTouch.TP_X;
// int ty = myTouch.TP_Y;
// XC= constrain (map(tx, 205, 3900,0,239),0,239);
// YC= constrain (map(ty, 300, 3850,0,319),0,319);
// GetNum();
void PassWord_makeButton()
for(int y = 0; y < 300;y+=100)
for(int x = 0; x < 200; x+=50)
drawButton(20+x, 90+y, 50+x, 30+y); // this will draw the button on the screen by so many pixels
return;
void drawButton(int x1, int y1,int x2, int y2)
myGLCD.setColor(170,170,170); // grey
myGLCD.fillRoundRect(y1-3, x1+3, y2-3, x2+3);//Button Shading
myGLCD.setColor(255, 255, 255); // white
myGLCD.fillRoundRect(y1, x1, y2, x2);// outter button color
myGLCD.setColor(200,0,0); // red
myGLCD.fillRoundRect(y1-5, x1+5, y2+5, x2-5);//inner button color
return;
void PassWord_buttonText()
myGLCD.setFont(BigFont);
myGLCD.setBackColor(200, 0, 0);
myGLCD.setColor(255,255,255);
for(int tr = 0; tr < 300; tr+=100)
for(int tc = 0; tc < 200; tc+=50)
char *myText = text[tc/50][tr/100];
myGLCD.print(myText, 52+tr, 27+tc, 0); //this will print the number into the center of the buttons
void GetNum()
char *myText;
if(myTFT.TouchButton(90+tr, 20+tc, 30+tr, 50+tc)) // this check to see if any of the buttons were pressed, then it sends the corresponding number to the "check" function
check(*myText);
void check(char pass)
Pass[Pcount] = pass; //store incoming numbers in an array
myGLCD.print(Pass,CENTER, 1); // show the password as it is being entered
if(Pcount == 3)// only when the array is filled, does it check the numbers
if(!strcmp(Pass, master)) // compare the password to the master password
myGLCD.print("GOOD",CENTER, 1);
myGLCD.print(" ",CENTER, 1);
myGLCD.print("FAIL",CENTER, 1);
clearPassword(); // Clear the password
Pcount++;
if(Pcount > 3) // this ensure the count does not exceed the maximum lenght of the password
Pcount = 0;
PassCounter = 0;
void clearPassword()
byte i = 3;
while(i != 0)
Pass[i--] = NULL;
//boolean TouchButton(int x1, int y1, int x2, int y2, int xc, int yc){
// if (orient==LANDSCAPE)
// xc = xc ^ yc;
// yc = xc ^ yc;
// xc = xc ^ yc;
// if (x1>x2)
// x1 = x1 ^ x2;
// x2 = x1 ^ x2;
// x1 = x1 ^ x2;
// if (y1>y2)
// y1 = y1 ^ y2;
// y2 = y1 ^ y2;
// y1 = y1 ^ y2;
// if(xc >= x1 && xc <= x2 && yc >= y1 && yc <= y2) return true;
// return false;
