I’m working on a grain humidity meter. So a couple of sensors sit in an Acrylic chamber with the mcu and battery pack in an adjacent chamber which is shown here in greyed out lines.
The two sensors (blue and fuscia) are shown inside the chamber and I’m thinking of simply adding a pullout latch (also of acrylic) with a stop at the end. The user would pour the grains into the chamber and push the latch back in and then take the measurements.
Sorry, the autocorrect changed chamber to hammer. There is no hammer.
It's for taking quick measurements. The sensing part is taken care of. At present I'm trying to figure out a way to get the grains in and out of the acrylic chamber which is roughly 2" x 2" x 6" tall.
Marciokoko:
Electronic humidity measurement is generally slow.
How fast do you intend this to take.
Given the size of your container it may tell you if the grain is wet but not give you a useful indication of the water content of the grain over a short timescale.
Do you want the moisture content of the grain, or the humidity of the air around the the grain.
If the latter you will need a very longtime for any moisture to evaporate out of the grain to humidify the air, and you need to know the moisture content of the air before you placed the sample in the chamber.
Current devices on the market use a screw cap which is cumbersome when sampling many times. It might be better but im looking for a tradeoff. Im looking for a quick and dirty way to sample and I want to compare what the losses are in accuracy or precision vs a market device.
They all measure the moisture content of the air around the grain, at least the field devices. Otherwise one would have to grind the sample first which would make the device more complex. More sophisticated devices do measure moisture content of the grains by cooking them and measuring the weight differential but those are lab devices.
