Hi!
I have created a code to run my analog sound sensor (DFRobot DFR0034) from my Arduino. The sensor is bringing in samples at a rapid rate. The data is half zeros (i assume this is not intended and it is probably noise) and I have based my calibration off of the max values recorded. So, my code for the sensor individually accounts for this and chooses the max value from the last 40 responses and uses that as the value from the sensor. Here is the code for this:
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
static int count = 0;
static float maxSoundValue = 0;
float rawsensorvalue = analogRead(A1);
if (rawsensorvalue > maxSoundValue) {
maxSoundValue = rawsensorvalue;
count++;
if (count == 40) {
float soundsensorvalue = maxSoundValue;
float y;
if (soundsensorvalue < 10) {
y = 0.826 * soundsensorvalue + 55.8;
y = 0.17 * soundsensorvalue + 65;
soundsensor = y;
Serial.println(soundsensor);
// Reset for next 40 data points
count = 0;
maxSoundValue = 0;
Here is the code for the entire system. It is a monitoring system for a warehouse. I just want the sound sensor to be able to operate the way it does on its own code, when it is integrated into the new code. For the life of me, I can not figure out why it doesn't work. Thanks for you help.
Sketch generated by the Arduino IoT Cloud Thing "Untitled 2"
https://create.arduino.cc/cloud/things/3451d766-df36-4ad9-8d01-5f06978edb88
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float cel;
float humidity;
float oxygenData;
float percentage_co2;
float sensor_volt_co;
float temperature_far;
int soundsensor;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// Temp and Humid needed info
#include <DHT.h>
#define DHTPIN 8
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
// CO2 sensor needed info
#define MG_PIN (0) //define which analog input channel you are going to use
#define BOOL_PIN (2)
#define DC_GAIN (8.5) //define the DC gain of amplifier
/***********************Software Related Macros************************************/
#define READ_SAMPLE_INTERVAL (50) //define how many samples you are going to take in normal operation
#define READ_SAMPLE_TIMES (5) //define the time interval(in milisecond) between each samples in
//normal operation
/**********************Application Related Macros**********************************/
//These two values differ from sensor to sensor. user should derermine this value.
#define ZERO_POINT_VOLTAGE (0.220) //define the output of the sensor in volts when the concentration of CO2 is 400PPM
#define REACTION_VOLTAGE (0.020) //define the voltage drop of
/*****************************Globals***********************************************/
float CO2Curve[3] = {2.602,ZERO_POINT_VOLTAGE,(REACTION_VOLTAGE/(2.602-3))};
//two points are taken from the curve.
//with these two points, a line is formed which is
//"approximately equivalent" to the original curve.
//data format:{ x, y, slope}; point1: (lg400, 0.324), point2: (lg4000, 0.280)
//slope = ( reaction voltage ) / (log400 –log1000)
// Oxygen sensor needed info
#include <DFRobot_OxygenSensor.h>
#define Oxygen_IICAddress ADDRESS_3
#define COLLECT_NUMBER 10
//collect number,the collection range is 1-100.
DFRobot_OxygenSensor oxygen;
delay(1500);
initProperties();
// Sound add-ons
// CO sensor add-ons:
pinMode(sensor_volt_co, INPUT);
// Temp and Humid sensor add-ons:
dht.begin();
// CO2 sensor add-ons:
pinMode(BOOL_PIN, INPUT); //set pin to input
digitalWrite(BOOL_PIN, HIGH); //turn on pullup resistors
// Oxygen sensor add-ons:
while(!oxygen.begin(Oxygen_IICAddress)){
Serial.println("I2c device number error !");
Serial.println("I2c connect success !");
// Your code here
//Sound Sensor Code:
count++;
if (count == 40) {
float y;
soundsensor = y;
Serial.print("sound level: ");
count = 0;
maxSoundValue = 0;
// CO sensor Code:
float rS_gas; // Get value of RS in a GAS
float ratio; // Get ratio RS_GAS/RS_air
int sensorValue = analogRead(A3);
sensor_volt_co=(float)sensorValue/1024*5.0;
rS_gas = (5.0-sensor_volt_co)/sensor_volt_co; // omit *RL
float r0 = 3.01;
ratio = rS_gas/r0; // ratio = RS/R0
Serial.print("sensor_volt = ");
Serial.println(sensor_volt_co);
// Temp and Humid Sensor code:
humidity = dht.readHumidity();// Read humidity
temperature_far = dht.readTemperature(true); // Read temperature in Fahrenheit
cel = dht.readTemperature();
Serial.print("Humid ");
Serial.print(humidity);
Serial.println("Temp ");
Serial.print(temperature_far);
//Oxygen Sensor Code
oxygenData = oxygen.getOxygenData(COLLECT_NUMBER);
Serial.print(" oxygen concentration is ");
Serial.print(oxygenData);
Serial.println(" %vol");
// CO2 sensor code
float volts;
volts = MGRead(MG_PIN);
Serial.print( "SEN-00007:" );
Serial.println(volts);
Serial.println( "V " );
percentage_co2 = MGGetPercentage(volts,CO2Curve);
Serial.print("CO2:");
if (percentage_co2 == -1) {
Serial.print( "<400" );
percentage_co2 = 400;
Serial.print(percentage_co2);
Serial.print( "ppm" );
Serial.print("\n");
if (digitalRead(BOOL_PIN) ){
Serial.print( "=====BOOL is HIGH======" );
Serial.print( "=====BOOL is LOW======" );
Serial.print("\n");
delay(200);
/***************************** MGRead *********************************************
Input: mg_pin - analog channel
Output: output of SEN-000007
Remarks: This function reads the output of SEN-000007
float MGRead(int mg_pin)
int i;
float v=0;
for (i=0;i<READ_SAMPLE_TIMES;i++) {
v += analogRead(mg_pin);
delay(READ_SAMPLE_INTERVAL);
v = (v/READ_SAMPLE_TIMES) *5/1024 ;
return v;
/***************************** MQGetPercentage **********************************
Input: volts - SEN-000007 output measured in volts
pcurve - pointer to the curve of the target gas
Output: ppm of the target gas
Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
of the line could be derived if y(MG-811 output) is provided. As it is a
logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
value.
int MGGetPercentage(float volts, float *pcurve)
if ((volts/DC_GAIN )>=ZERO_POINT_VOLTAGE) {
return -1;
return pow(10, ((volts/DC_GAIN)-pcurve[1])/pcurve[2]+pcurve[0]);
Since Soundsensor is READ_WRITE variable, onSoundsensorChange() is
executed every time a new value is received from IoT Cloud.
void onSoundsensorChange() {
// Add your code here to act upon Soundsensor change
Since SensorVolt is READ_WRITE variable, onSensorVoltChange() is
void onSensorVoltChange() {
// Add your code here to act upon SensorVolt change
Since Humidity is READ_WRITE variable, onHumidityChange() is
void onHumidityChange() {
// Add your code here to act upon Humidity change
Since TemperatureFar is READ_WRITE variable, onTemperatureFarChange() is
void onTemperatureFarChange() {
// Add your code here to act upon TemperatureFar change
Since Percentage is READ_WRITE variable, onPercentageChange() is
void onPercentageChange() {
// Add your code here to act upon Percentage change
Since OxygenData is READ_WRITE variable, onOxygenDataChange() is
void onOxygenDataChange() {
// Add your code here to act upon OxygenData change
Since SensorVoltCo is READ_WRITE variable, onSensorVoltCoChange() is
void onSensorVoltCoChange() {
// Add your code here to act upon SensorVoltCo change
Since PercentageCo2 is READ_WRITE variable, onPercentageCo2Change() is
void onPercentageCo2Change() {
// Add your code here to act upon PercentageCo2 change
Since Cel is READ_WRITE variable, onCelChange() is
void onCelChange() {
// Add your code here to act upon Cel change
