Sanguino with a serial port
Has anyone built a Sanguino with MAX232 to connect to COM1 port of a desktop PC?
Can he/she please share the schematic?
I have built one and it is not working.
I am slightly confused whether RTS or DTR line should be used for resetting the chip.
Regards,
-P W Dandekar
I had one of these development boards from Sparkfun which I put a 644P in and converted it to use the Sanguino bootloader. I just put a header on to connect a FTDI programing cable, and it was then a sanguino with a serial port.
Have a look at the schematic of the board to find out how to do the MAX232 part.
Hope that is of some help
James
Thanks James,
I looked at the Sparkfun schematic as well as similar board from www.olimex.com/dev - AVR-P40-8515.
In both cases, they have converted DTR/RTS signals from RS232 to TTL and left them unconnected on pins. They have not connected RTS/DTR signal to RESET via a 0.1 mfd capacitor as they do in FREEDUINO Serial or SEVERINO.
If you look at the Sanguino schematic by Zack Hoeken, you will see RTS connected to RESET via a 0.1 mfd capacitor. But he uses a FTDI USB to 232 converter chip.
I wanted to try the same here with MAX232.
Thanks again.
-Prakash
