Sanguino: wrong signature?
Hi!
I built a very compact Sanguino on stripboard, but I happen to have problems.
I installed Sanguino files in the IDE.
I use an USBtinyISP.
I disconnected all other arduino boards from the computer.
I couldn't burn the bootloader from the IDE because it told me that I should check the connections.
So I burnt it using
avrdude -p m644p -c usbtiny -P usb -B 8 -F -u -U flash:w:/Applications/Arduino.app/Contents/Resources/Java/hardware/bootloaders/atmega644p/ATmegaBOOT_644.hex
Everything seemed ok :
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9609
avrdude: Expected signature for ATMEGA644P is 1E 96 0A
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/Applications/Arduino.app/Contents/Resources/Java/hardware/bootloaders/atmega644p/ATmegaBOOT_644.hex"
avrdude: input file /Applications/Arduino.app/Contents/Resources/Java/hardware/bootloaders/atmega644p/ATmegaBOOT_644.hex auto detected as Intel Hex
avrdude: writing flash (65370 bytes):
Writing | ################################################## | 100% 102.64s
avrdude: 65370 bytes of flash written
avrdude: verifying flash memory against /Applications/Arduino.app/Contents/Resources/Java/hardware/bootloaders/atmega644p/ATmegaBOOT_644.hex:
avrdude: load data flash data from input file /Applications/Arduino.app/Contents/Resources/Java/hardware/bootloaders/atmega644p/ATmegaBOOT_644.hex:
avrdude: input file /Applications/Arduino.app/Contents/Resources/Java/hardware/bootloaders/atmega644p/ATmegaBOOT_644.hex contains 65370 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 49.16s
avrdude: verifying ...
avrdude: 65370 bytes of flash verified
avrdude done. Thank you.
I now changed upload.using in the preferences.txt file to use usbtinyisp.
I now get the following error uploading:
Double check chip, or use -F to override this check.
What could I do?
I see a ATmegaBOOT_644P.hex file in the bootloader folder, should I use this one? I use a DIP version of the 644...
Thanks :wink:
Oh yes, and the Sanguino happens to blinks 3 times (with 2 sec between) after reset and 8 seconds later one time.
I know that for Arduino Diecimila this was because the NG bootloader was burnt...
I tried to burn
avrdude -p m644p -c usbtiny -P usb -B 8 -F -u -U flash:w:/Applications/Arduino.app/Contents/Resources/Java/hardware/bootloaders/atmega644p/ATmegaBOOT_644P.hex
But it doesn't change anything :-/
Ii have a sanguino that works and i can check the sig for you.
Have you looked at the datasheet to see what it should be?
Thanks for you reply.
The error message says that it should be 1E 96 0A. That's perhaps a firmware problem but I don't see why it does't work, I think I burnt it properly?
What surprises me is the first error message I got as I tried to burn from within the IDE. :-/ Why can't I burn it from the IDE?
An idea anyone?
I think I got it : I have a 644-20PU instead of a 644
I will try http://dev.forums.reprap.org/read.php?13,29956,29956
Solved! :wink:
... but I don't have the second UART :cry:
