If you look at the schematic diagram for a diode bridge rectifier that is drawn with the AC inputs at the top and bottom you will see that all of the diodes point in one direction. You will also see that there is a connection, either input or output, at each end of each diode. This information should help you in drawing/analyzing your pc board layout.
yes i have seen that and there is also a variation to that design
But your diagram is not a variation to the design of the circuit, it is a variation of how the same circuit could be drawn. A schematic diagram, of which this diagram would be a part, should make the signal flow as easy to follow as possible. That almost always means flow from left to right. Any unnecessary flow in the other direction, even if not incorrect, just obfuscates* things.
Don
To make so confused or opaque as to be difficult to perceive or understand.
(Like the use of the word obfuscate)
