Save data from arduino to excel using PLX-DAQ
hi
i’m new in both programming and arduino. I have uploaded this code to detect motion thru arduino. I need to store the outputs in excel using PLX-DAQ. But when i connect the code with PLX-DAQ, no output appear. currently, my arduino circuit contain pir sensor and real time clock device. can someone help me ?
#include
#include “RTClib.h”
#define DS32321_ADDRESS 0x68
byte zero = 0x00;
int ledPin = 13;
int inputPin = 2;
int pirState = LOW;
int val = 0;
long unsigned int pause = 5000;
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = {“Sunday”, “Monday”, “Tuesday”, “Wednesday”, “Thursday”, “Friday”, “Saturday”};
void setup(){
pinMode(ledPin, OUTPUT);
pinMode(inputPin, INPUT);
#ifndef ESP8266
while (!Serial); // for Leonardo/Micro/Zero
#endif
delay(3000); // wait for console opening
if (! rtc.begin()) {
Serial.println(“Couldn’t find RTC”);
while (1);
if (rtc.lostPower()) {
Serial.println(“RTC lost power, lets set the time!”);
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void loop(){
val = digitalRead(inputPin); // read sensor value
if (val == HIGH) { // check if the sensor is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
delay(100); // delay 100 milliseconds
if (pirState == LOW) {
Serial.println(“Motion detected!”);
printDate();
pirState = HIGH; // update variable state to HIGH
else {
digitalWrite(ledPin, LOW); // turn LED OFF
delay(200); // delay 200 milliseconds
if (pirState == HIGH){
pirState = LOW; // update variable state to LOW
void printDate(){
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print(‘/’);
Serial.print(now.month(), DEC);
Serial.print(‘/’);
Serial.print(now.day(), DEC);
Serial.print(” (“);
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(“) “);
Serial.print(now.hour(), DEC);
Serial.print(‘:’);
Serial.print(now.minute(), DEC);
Serial.print(‘:’);
Serial.print(now.second(), DEC);
delay(3000);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
At the top of this Forum is a post that says: How to use this forum - Please read. Why did you ignore that advice?
PLX works with Office 2003 and earlier. All your time stuff is redundant. Excel can handle that. You should be able to test everything simply by sending the output to the serial monitor. Have you done that?
