Save data in Excel to an SD Card Problem
hello everyone i have made the following code allowing me to save my data in excels table files.
The problem is the following:
If I plug in to save and then unplug my SD card to read the data and then plug it back in, there are already files inside and my code can't write to the next file or to a new file.
I'm looking for a way to get back to my previous table and continue writing in it.
The code :
//********************* Program SETUP *****************************
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
    Serial.println("MCP2515 Initialized Successfully!");
    Serial.println("Error Initializing MCP2515...");
  CAN0.setMode(MCP_NORMAL);  // Set operation mode to normal so the MCP2515 sends acks to received data.
  pinMode(CAN0_INT, INPUT);  // Configuring pin for /INT input
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  Serial.println("MCP2515 Library Receive Example...");
  while(!SD.begin(SD_CS_PIN));
    SERIAL_PORT_MONITOR.println("SD card is present & ready");
    sprintf(filename, "can_%.03d.csv", i);  //initialise filename
    myFile = SD.open(filename, FILE_WRITE);
    if (myFile) // it opened OK
      myFile.println("Time,Pression,Temperature,co2_hydrogen,humidity"); //add header to file
      myFile.close();
      SERIAL_PORT_MONITOR.println("File created!");
      SERIAL_PORT_MONITOR.println("Error opening file");
//*********************   Write into Excel  ***********************
void writeToFile(float press_pascal, float temp_degC, float co2_true, float humi_pourcent)
    myFile.print(String(minute()));
    myFile.print(":");
    myFile.print(String(second()));
    myFile.print(";");
    myFile.print(String(press_pascal, 2));
    myFile.print(";");
    myFile.print(String(temp_degC, 2));
    myFile.print(";");
    myFile.print(String(co2_true, 2));
    myFile.print(";");
    myFile.println(String(humi_pourcent, 2));
    myFile.close();
//********************* Program LOOP ***************************
  if (digitalRead(buttonPin)== HIGH)
    digitalWrite(ledPin, HIGH);  // turn LED on
  if(!digitalRead(CAN0_INT))                         // If CAN0_INT pin is low, read receive buffer
    CAN0.readMsgBuf(&rxId, &len, rxBuf);      // Read data: len = data length, buf = data byte(s)
  if((rxId & 0x80000000) == 0x80000000)     // Determine if ID is standard (11 bits) or extended (29 bits)
      sprintf(msgString, "Extended ID: 0x%.8lX  DLC: %1d  Data:", (rxId & 0x1FFFFFFF), len);
      sprintf(msgString, "Standard ID: 0x%.3lX       DLC: %1d  Data:", rxId, len);
    Serial.print(msgString);
   if((rxId & 0x40000000) == 0x40000000){    // Determine if message is a remote request frame.
      sprintf(msgString, " REMOTE REQUEST FRAME");
      Serial.print(msgString);}
    for(byte i = 0; i<len; i++)
      sprintf(msgString, " 0x%.2X", rxBuf[i]);
    Serial.println("_____Pression_____");
    uint16_t press_raw;
    memcpy(&press_raw, &rxBuf[0], 2); //buf[0] is the first byte in buf, 2 because you want 2 bytes
    float press_pascal = ((press_raw * 0.0078125) - 250);
    Serial.println(press_pascal, 2);  // value to copy on excel
    Serial.println("_____Temperature_____");
    uint16_t temp_raw;
    memcpy(&temp_raw, &rxBuf[2], 2); //buf[2] is the third byte in buf, 2 because you want 2 bytes
    float temp_degC = ((temp_raw * 0.03125)-273)-3 ;
    Serial.println(temp_degC, 2);
    Serial.println("_____CO2_Hydrogen_____");
    uint16_t co2_raw;
    memcpy(&co2_raw, &rxBuf[4], 2); //buf[4] is the fifth byte in buf, 2 because you want 2 bytes
    float co2_true = ((co2_raw * 1) - 0) ;
    Serial.println(co2_true, 2);
    Serial.println("_____Humidity_%_____");
    uint16_t humi_raw;
    memcpy(&humi_raw, &rxBuf[6], 2); //buf[6] is the six byte in buf, 1 because you want 1 bytes
    float humi_pourcent = ((humi_raw * 0.4) - 0);
    Serial.println(humi_pourcent, 2);
    writeToFile(press_pascal, temp_degC, co2_true, humi_pourcent);
    ++reads_recorded;
         digitalWrite(ledPin, LOW); // turn LED off
         Serial.println("off");
//********************* Makes new files excel ***********************
  //create new filenames for every 5400 lines written to file
  if(reads_recorded == 5400) {  //reset counter
    reads_recorded = 0;
    //increment file counter
    ++i;
    //update finename
      //add header to new file
      myFile.close();
      SERIAL_PORT_MONITOR.println("New File created!");
That code does not compile.
Its because is very long , it works I use it on my project but I would like to solve my problem stated above
My all code :
#include <SD.h>
#include <TimeLib.h>
#include <mcp_can.h>
#include <SPI.h>
//*********************CAN Sheild declarations********************
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128]; // Array to store serial string
#define CAN0_INT 2   // Set INT
MCP_CAN CAN0(53);    // Set CS
//*********************SD Sheild declarations**********************
File myFile;
const int SD_CS_PIN = 9;
//*********************Record Excel declarations*******************
char filename[16];
unsigned long reads_recorded = 0;
uint16_t i = 0;
//*********************Switch and Led declarations*****************
const int buttonPin = 40;     // the number of the pushbutton pin
const int ledPin =  41;      // the number of the LED pin
      myFile.close();
    myFile.print(":");
    myFile.print(";");
    myFile.print(";");
    myFile.print(";");
    myFile.print(";");
    myFile.close();
    uint16_t press_raw;
    uint16_t temp_raw;
    uint16_t co2_raw;
    uint16_t humi_raw;
    ++reads_recorded;
    reads_recorded = 0;
    ++i;
    //update finename
      myFile.close();
