Save data to SD card
Hello everybody,
I'm doing a project about weighting scale and I'm stuck at the data saving part.
My goal is to save a users card UID and all the items he weighted for a day to his account.
Example:
User UID: 95 7E 60 50
Checked In: 9:00 AM 03.12.19
Measured PCS: 3000
Checked Out: 17:00 PM
It will be even better if i would be able to save how much PCS he weighted at what our, but in the end i need the sum of all items for the day.
I achieved saving the items to a txt file with for cycle.
The problem with the card UID is that it saves multiple times with the items and i only need it once as i mentioned earlier.
If you can point me to solution I'll be very thankful.
ALSO I'm not using an RTC module because i have only DS1302 which i figured out is really frustrating, so i removed it completely.
Here is the code:
#include "HX711.h"
#include <LiquidCrystal.h>
#include <SPI.h>
#include <MFRC522.h>
#include <SD.h> // for the SD card
#define SS_PIN 10
#define RST_PIN 9
#define CS_SD 3
// Create a file to store the data
File myFile;
// Variable to hold the tag's UID
MFRC522 mfrc522(SS_PIN, RST_PIN);
HX711 scale;
float elements = 2.5;
LiquidCrystal lcd(A2,A1,5,4,A0,A5);
const int BackLight = 8;
String LCDLine1,LCDLine2;
int n;
const int buzzer = 7;
float rounded;
void updateLCD () {
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(LCDLine1);
  lcd.setCursor(0,1);
  lcd.print(LCDLine2);
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  lcd.begin(16,2);
  pinMode(BackLight, OUTPUT);
  digitalWrite(BackLight, HIGH);
  LCDLine1="Welcome";
  LCDLine2="Scan your ID";
  updateLCD();
  if (SD.begin(CS_SD))
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  while(true){
  // Look for new cards02`11
  if ( ! mfrc522.PICC_IsNewCardPresent())
    continue;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
  tone(buzzer, 1000); // Send 1KHz sound signal...
  delay(1000);        // ...for 1 sec
  noTone(buzzer);     // Stop sound...
  digitalWrite(CS_SD,LOW); // enables the cs pin
  // If the file opened ok, write to it
    if (myFile) {
    Serial.println("Read:");
    // Reading the whole file
    while (myFile.available()) {
      Serial.write(myFile.read());
    myFile.close();
  else {
    Serial.println("error opening test.txt");
    digitalWrite(CS_SD,HIGH);
  while(true){
  //Show UID on serial monitor
  Serial.print("UID tag :");
  String content= "";
  byte letter;
   for (byte i = 0; i < mfrc522.uid.size; i++)
     Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     Serial.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  Serial.print("Message : ");
  content.toUpperCase();
  if (content.substring(1) == "9E 7E 85 89") //change here the UID of the card/cards that you want to give access
    Serial.println("Authorized access");
    delay(3000);
 else   {
    Serial.println(" Access denied");
    delay(3000);
  Serial.println("HX711 Demo");
  LCDLine1="Initializing ...";
  LCDLine2="";
  updateLCD();
  // parameter "gain" is ommited; the default value 128 is used by the library
  // HX711.DOUT  - pin #A1
  // HX711.PD_SCK - pin #A0
  scale.begin(A4, A3);
  scale.set_scale(1900.f);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare();               // reset the scale to 0
  Serial.println("After setting up the scale:");
  Serial.print("read: \t\t");
  Serial.println(scale.read());                 // print a raw reading from the ADC
  Serial.print("read average: \t\t");
  Serial.println(scale.read_average(20));       // print the average of 20 readings from the ADC
  Serial.print("get value: \t\t");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight, set with tare()
  Serial.print("get units: \t\t");
  Serial.println(scale.get_units(10), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
            // by the SCALE parameter set with set_scale
  Serial.println("Readings:");
void Scale()
     float average = scale.get_units(10);
if (average < 0.3)
average = 0;
  float number =  scale.get_units()/elements;//divide the average of 20 readings with the elements value to get the number of elements
   n = round(number);
   //n = (int)number; // convert float into int
  Serial.print("\t| elements:\t");
  Serial.print(n); //serial monitor
  // lcd.clear();
       //set cursor first row
  LCDLine1=String(average,1)+" g"; //print on lcd average value from 10 raw readings 1 time
  LCDLine2=String(n)+" pcs";
  Serial.print("\t| average:\t");
  Serial.println(average); // serial monitor -||-
   //print PCS
  scale.power_down();             // put the ADC in sleep mode
  scale.power_up();
  updateLCD();
  void myfile()
  String content= "";
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    for (int n=0; n==0; n++)
    myFile.print(n, DEC);
    myFile.print("/");
     myFile.print("/");
     myFile.print(String(mfrc522.uid.uidByte[i], HEX));
    Serial.println("sucessfully written on SD card");
    myFile.close(); // close the file
 Scale();
 updateLCD();
 myfile();
You failed to provide links to the used hardware so I simply assume you use one of these cheap Chinese SD card readers that has a wrongly implemented SPI level converter on it. If you're an experience solderer you may fix it (there are tutorials on the Net about how to do that), otherwise buy an SD card reader from one of the serious suppliers (Sparkfun, Adafruit, etc.).
