save dynamic value come from sensor to database
i user EtherCard to save data to database and every thing is goo if i sent fixed value in link as below
 ether.browseUrl(PSTR("/ardu/Default2.aspx?occupation="), "123", website, my_result_cb);
but when i try to replace fixed val with dynamic value come from sensor it was sent blank value to database
    int power = 200; // fill that with your value
    char test[10] ;
    snprintf(test, 10, power);
    Serial.println("Test=");
    Serial.println(test);
    ether.browseUrl(PSTR("/ardu/Default2.aspx?occupation="), test, website, my_result_cb);
    char test[10] ;
How many arguments does snprintf()? What are they?
int snprintf ( char * s, size_t n, const char * format, ... );
So, you told snprintf() to write to test, not more than 10 characters, using 200 as the format, with no value to be formatted.
What do you expect test to contain, then?
thank for your replay PaulS
can you please correct my code
Yes. I fired up the IDE and fixed it. Works great now.
Of course, I KNOW how to use snprintf(). Apparently you don't. Mr. Google has all day to help you learn. I don't.
