Save EEPROM data in textfile
Hello.
I've thought collecting data from a detector for several days by writing in the EEPROM, then reading the contents of the EEPROM, copying the data and analyzing it with MATLAB, EXCEL and etc.
The surprise was that I can not copy the numbers from SERIAL MONITOR.
Some ideas?
Well, I have just found this item in old forums.
I wil read them.
A proper terminal emulator will allow you to write serial output to a file.
eg realTerm...
Allan
LuchezarBalchikliev:
Some ideas?
What do you mean by "can not copy"? All you need to do is select the numbers with the mouse or click on the Serial Monitor and then press ctrl+a to select all, then ctrl+c to copy. It works fine for me I do it all the time.
