Save Ports Name in array
I would to save the portname in an array for use with a "for" istruction (I use it, for read the configured pinmode from the eeprom).
I'v tryed creating a byte array wich contains the ports name:
const byte ANALOG_PINS[ANALOG_NR_PINS] = {
  A0,A1,A2,A3,A4,A5 };
const byte DIGITAL_PINS[DIGITAL_NR_PINS] = {
  6,7,8,9};
But it works well for the Digital Pins, and give a weird output for the Analog Pins.
It is the serial output:
Reading configuration...
D6 INPUT - State: 0
D7 INPUT - State: 0
D8 INPUT - State: 0
D9 INPUT - State: 0
 INPUT - State: 0
 INPUT - State: 0
 INPUT - State: 0
 INPUT - State: 0
 INPUT - State: 0
 INPUT - State: 0
How may I can get the portname A0,A1 for Analogs pins... ?
I'v tryed with somethings like:
String tmp = ANALOG_PINS[i];
Serial.println(ANALOG_PINS[i]);
But it didnt work too.
Someone may help me ?
Thank you,
Best Regards
Full code:
#include <EEPROM.h>
/* Set how many pin we have, and their name */
const byte ANALOG_NR_PINS = 6;
const byte DIGITAL_NR_PINS = 4;
  6,7,8,9};
  Serial.println("Reading configuration... ");
  for (int i = 0; i <= DIGITAL_NR_PINS-1; i++) {
    int conf = EEPROM.read(i+6);
    int val = digitalRead(DIGITAL_PINS[i]);
    Serial.print("D");
    Serial.print(DIGITAL_PINS[i], DEC);
    Serial.print("\t");
    switch (conf) {
    case 0:
      Serial.print("INPUT - State: ");
      Serial.println(val);
      pinMode (DIGITAL_PINS[i], INPUT);
    case 1:
      Serial.print("OUTPUT - State: ");
      pinMode (DIGITAL_PINS[i], OUTPUT);
    default:
      Serial.print("INVALID VALUE - NOT CONFIGURED: ");
      Serial.print(conf);
  for (int i = 0; i <= ANALOG_NR_PINS-1; i++) {
    int conf = EEPROM.read(i);
    int val = digitalRead(ANALOG_PINS[i]);
    Serial.print(ANALOG_PINS[i]);
    Serial.print("\t");
    switch (conf) {
    case 0:
      pinMode (ANALOG_PINS[i], INPUT);
    case 1:
      pinMode (ANALOG_PINS[i], OUTPUT);
    default:
  // idling...
A0, A1, etc. are aliases for the actual pin number (14, 15, ... on the UNO). You won't get the Arduino to print A0, A1, etc., easily. Getting it to print 14, 15, etc. is easy.
Serial.println(ANALOG_PINS[ i ], DEC);
Serial.println(DIGITAL_PINS[ i ], DEC);
PaulS:
Ah.. it was the reason that I got 14,15 etc... when using it with DEC.
Maybe, I'v to do a String array for keep their name in a "human-readable" way and with a function wich count from 14 To the PinNum requested return the portname.
Thank you,
Best Regards
