Is there a way to extract the lower half of the 64-bit address of the source XBee of a receive packet, and save it to an uint8_t array? (e.g. If I received a packet from 0013A200 4157310A, I will save {41 57 31 0A} to an uint8_t array.)
I am using XBee.h library by Andrew Rapp, and XBee Zigbee PRO modules.
Why do you want to do that?
Post the code that you have now. Saving the upper and lower 32 bit parts of the address as two uint32_t variables, or an array with two elements makes sense. Saving the data as an array of bytes is possible, but why?
