How is serial data saved in IDE version 2.3.2? Am I mistaken, or do I remember correctly that in the earlier version of the Arduino IDE the mouse cursor could be placed in the serial monitor window, select all, copy, & paste raw data into a spreadsheet for graphing, and other data modeling purposes. Please refer to any established discussions on the subject.
It's a glitch in the Arduino system, whether by accident, or by design. I am looking at that "SparkFun Qwiic OpenLog" as an alternative, to be ordered with the generic Uno board, and Quick cable. I have purchased from SparkFun before and I am confident in the technical assistance provided (if needed.) I posted, here, to make sure I am not missing something simple with the new IDE. Thanks for your interest, and please update your progress.
"Product improvement is the first stage of obsolescence." (anonymous)
J-M-L
April 30, 2024, 6:47am
6
you can go and use another terminal that really works (coolTerm, PuTTY, Tera Term, RealTerm, ...) or just the command line (depending on your OS) to collect the communication directly into a file.
I posted that in the hope that the OP might realize there was a place to post that particular question, and that they might have looked just a little bit further to find it. The post I quoted is on the first page in the IDE 2.0 forum, so it's not hard to find.
or install IDE 1.8.19 as well as IDE 2.x
J-M-L
April 30, 2024, 11:21am
9
Deva_Rishi:
as well as IDE 2.x
it seems to have more limitations than the IDE 1.8.19
Hi @UbuAnon . The Arduino IDE developers are tracking the need to support copying all the data from the Serial Monitor here:
opened 11:30PM - 05 Feb 22 UTC
topic: code
type: imperfection
topic: serial monitor
### Describe the problem
Let's say I have 1000 lines of debug output in the s… erial monitor window, how do I do a select all, such that I can copy it to the
clipboard?
With 1.8.19, I click the mouse into the monitor window and hit <kbd>**Ctrl**</kbd>+<kbd>**A**</kbd> and it selects all of the text. I can then hit <kbd>**Ctrl**</kbd>+<kbd>**C**</kbd>
to copy to clipboard.
### To reproduce
Run a sketch and try to select all of the text from Serial Monitor.
🐛 The contents of the sketch editor are selected when you press <kbd>**Ctrl**</kbd>+<kbd>**A**</kbd>:
### Expected behavior
I expected hitting <kbd>**Ctrl**</kbd>+<kbd>**A**</kbd> would select everything in that window not the source window.
### Arduino IDE version
#### Original report
Nightly build
#### Last verified with
9a6a457bc44fb16f646b9e61a9e8b336b3666412
### Operating system
Windows
### Operating system version
Not provided
### Additional context
And/Or alternative solution - context menu like for example TyCommander
Additional reports
- https://github.com/arduino/arduino-ide/issues/899
- https://github.com/arduino/arduino-ide/issues/1817
- https://github.com/arduino/arduino-ide/issues/1654
- https://github.com/arduino/arduino-ide/issues/1918
- https://github.com/arduino/arduino-ide/issues/2328
- https://forum.arduino.cc/t/copy-of-the-serie-monitor-output/1056049/1
- https://forum.arduino.cc/t/copy-of-the-serie-monitor-output/1056049/5
- https://forum.arduino.cc/t/serial-monitor-copy-only-copied-the-visible-logs/1051846/1
- https://forum.arduino.cc/t/serial-monitor-copy-only-copied-the-visible-logs/1051846/4
- https://forum.arduino.cc/t/using-v-2-0-serial-monitor-print/1034093
- https://forum.arduino.cc/t/serial-monitor-issues-hopefully-fixed-before-release/1026548
- https://forum.arduino.cc/t/serial-output-window-select-all-copy/1024251
- https://forum.arduino.cc/t/coping-multiple-lines-on-monitor-screen/1019346
- https://forum.arduino.cc/t/text-selection-serial-monitor/1005262
- https://forum.arduino.cc/t/upgrade-the-serial-monitor-for-better-function/980128
- https://forum.arduino.cc/t/ide-2-0-copy-from-serial-monitor-limited/1078391
- https://forum.arduino.cc/t/random-seed-does-not-deliver-random-numbers/1006762/10
- https://forum.arduino.cc/t/copying-from-serial-monitor/1071503/3
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/5
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/19
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/21
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/23
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/32
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/38
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/39
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/45
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/46
- https://forum.arduino.cc/t/copy-paste-data-from-the-serial-monitor/1041585/48
- https://forum.arduino.cc/t/arduino-ide-2-0-3-serial-monitor-cant-use-cntrl-a-to-capture-everything/1095266
- https://forum.arduino.cc/t/arduino-ide-serial-monitor-bug/1112653/7
- https://forum.arduino.cc/t/why-does-click-into-serial-monitor-ctrl-a-mark-the-source-code/1128016
- https://forum.arduino.cc/t/cannot-select-all-of-serial-data/1158236
- https://forum.arduino.cc/t/how-can-i-copy-the-whole-content-of-the-serial-monitor/1168904/1
- https://forum.arduino.cc/t/your-reason-for-not-switching-to-the-2-x-ide/1176322/47
- https://forum.arduino.cc/t/code-in-the-arduino-is-fine-but-the-display-show-nothing/1204977/33
- https://forum.arduino.cc/t/ide-2-addition-suggestions-open-source-participation/1204792
- https://forum.arduino.cc/t/save-serial-data/1253788
#### Related
- https://github.com/arduino/arduino-ide/issues/1081
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://www.arduino.cc/en/software#nightly-builds)
- [X] My report contains all necessary details
If you have a GitHub account, you can subscribe to that thread to get notifications of any new developments related to this subject:
I just ordered a MKR Zero, with built-in micro SD card. Theoretically (at this point) sensor data can be printed to the sd card, and the sd data copied to my desktop for spreadsheet use. When the board arrives, and it is plugged in and working, I will go to the MKR Zero forum to ask for advice how to modify my sensor script to include logging data on the card. This feels like a better plan than trying to copy text data from the new version of the IDE. Thanks for all replies to my original topic. It helps!
But ignores many other possibilities, including receiving serial data directly on the analysis PC, using several methods mentioned.
But, YMMV.
system
Closed
October 27, 2024, 1:30pm
13
