Save serial.println to file
Is it possible to save the serial.println data to a actual file. In colums
You can copy and paste from Serial Monitor.
If you want neat columns you can use the tab ("\t") character.
If you want to import into a spreadsheet you can use commas to separate fields and save the text in a .csv (Comma Separated Values) file. Then import that into your spreadsheet.
Its great but how do I save it to a cvs file?
mogren3000:
Like I said before:
johnwasser:
a .csv file can also work with tabs .... not necessary , 's
using another terminal program - e.g. putty.exe - can automatically capture received bytes to a file.
johnwasser:
mogren3000:
Like I said before:
johnwasser:
So the only way is to copy and paste. I had hoped that I could save it to a simple textfile or a datasheet of some sort.
mogren3000:
The EASIEST way is to copy and paste.
You can use a third-party terminal emulator (such as the Putty mentioned above), or write a custom program in whatever language you like to read from the serial port and write to a file, or add an SD card to your project and write directly to a file which you could then import into a PC, or use and Arduino Leonardo and emulate a USB keyboard to type the data directly into the program of your choice.
