Hi, I need to parse String and save number to int array.
At input I have s = E225@ a = "E"
My code:
int tempC[3];
void parseTemp(String s, char a) {
byte pos=0;
switch ( a ) {
case 'E':
pos=0;
case 'F':
pos=1;
case 'G':
pos=2;
default:
tempC[pos] = strtol(s.charAt(1), NULL, 10); // line 187
This should make tempC[0] = 225.
Compile produce an error:
arduino.ino: In function ‘void parseTemp(String, char)’:
arduino:187: error: invalid conversion from ‘char’ to ‘const char*’
arduino:187: error: initializing argument 1 of ‘long int strtol(const char*, char**, int)’
To give a proper answer we need to see your whole program or an example that illustrates the problem.
More generally, you will be advised to use C style strings instead of Strings as they can cause less problems in the limited memory available to most Arduinos.
String s = "E225@";
char a = 'E';
int tempC[3];
byte pos=0;
switch ( a ) {
case 'E':
pos=0;
case 'F':
pos=1;
case 'G':
pos=2;
default:
parseTemp(s, a);
tempC[pos] = strtol(&s.charAt(1), NULL, 10); // line 187
tempC[pos] = strtol(*s.charAt(1), NULL, 10); // line 187
do not work:
arduino:187: error: lvalue required as unary ‘&’ operand
All the String remarks are really valid, so give them the attention they deserve
still something like this should do the job
#include <ctype.h>
String s = "E225@";
int x = 0;
int index = 0;
while (s.charAt(index) != '@')
if ( isdigit(s.charAt(1)) )
x *= 10;
x += s.charAt(index) - '0';
index++;
Some test code that captures a numeric value from a character string sent to the arduino.
//zoomkat 10-16-14 simple delimited '@' string parse
//from serial port input (via serial monitor)
//and print result out serial port
String readString, subString;
Serial.println("String parse test"); // so I can keep track of what is loaded
//expect a string like E225@, F225@, or G225@
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == '@') {
if (readString.length() >0) {
Serial.println(readString); //prints string to serial port out
subString = readString.substring(1); //skips first character in readString
int n = subString.toInt(); //convert subString into a number
if(readString.indexOf('E') >-1) {
Serial.print("E value is: ");
Serial.println(n);
if(readString.indexOf('F') >-1) {
Serial.print("F value is: ");
Serial.println(n);
if(readString.indexOf('G') >-1) {
Serial.print("G value is: ");
Serial.println(n);
//do stuff with the captured subString
readString=""; //clears variable for new input
subString="";
else {
readString += c; //makes the String readString
Function need to obtain a pointer to the string (e.g. &s[1]) not a character.
I don't see any strings in the code snippet. A String, yes but no strings.
Really? It is not about the String but about "pointer to the string" , (const char *) or (char *) in other words in C language (string = chain of characters).
Wrong.
Function charAt() returns a character at some position in buffer of String object. It is a copy of real memory cell so no witchery with the pointers can help.
Function strtol() expects pointer to the string, a (const char *) - address of real memory place to be able go throughout character sequence controlled by String object. The &s[] does it.
tempC[pos] = strtol(&s[1], NULL, 10);
Should work fine.
There is function c_str() which returns a pointer to the string.
Here is the code posted by the OP
int tempC[3];
byte pos=0;
switch ( a ) {
case 'E':
pos=0;
case 'F':
pos=1;
case 'G':
pos=2;
default:
