I have a problem, and I need your help. I need read rfid token from card. I want save string "msg" in EEPROM and read EEPROM in computer because I dont know token what my card have. "00402B4D533F" is only sample.
I want save string 'msg' witch my token to EEPROM and read EEPROM with program "SinaProg". I connected by USBasp, so cant use Serial Monitor in Arduino IDE
I use USBasp so cant see RFID id in Serial Monitor.
I dont have Arduino. I have ATmega8, USBasp, and use Arduino IDE.
I read RFID id and have it in string "msg". String "msg" I want save in EEPROM. When id of my tag is in EEPROM i read it by SinaProg. But.. How to save string "msg" in EEPROM.
First off, you don't have a string, you have a String. Big difference. You need to iterate through each character, and put it in EEPROM. Alternatively, you can just put them in EEPROM as you read the individual bytes; unless you're doing comparisons, you don't need to put it into a string.
Why? Why are you not using a USB cable so you CAN use the Serial Monitor?
I'm trying to do this three days, but nothing.
It does not take three days to post ALL of your code. Get rid of the String class. Learn to use strings (NULL terminated array of char) for fixed length data, like RFID tags.
rotflol:
Because I have only microBoard M8 witch ATmega8 and USBasp. I dont have arduino... but I use Arduino IDE
It's hard to make sense of your description of what you're trying to achieve, but if I understood you correctly then you have a sketch that is obtaining a number from some other device and you want to know what the number is. You can't simply print it over the serial interface because your serial interface is not connected to USB and so you have no obvious way to get data from the 'microBoard' to the PC.
So the question is how to get data from your 'microBoard' to the PC.
Unless your microcontroller vendor provides some other mechanism, I would have thought your best bet was to obtain a TTL-serial-to-USB adapter and use that to provide a serial connection to the PC. They are inexpensive and readily available. If you don't like that then your next option is to buy an Arduino or clone that does provide a USB serial connection, and use a software serial connection to pass the data from the other microcontroller to the Arduino and hence to the PC.
If I am correct in understanding that you don't have any way to get serial output from your device so far, I would consider this a huge inconvenience in its own right so adding a serial-to-USB interface would be invaluable anyway.
